Just seen on SE Gen that 375607 has passed signal AD679 at danger
According to gen reports the signal was clear as the driver approached but then changed to danger just as he approached it
Apparently the train is now blocking point work
Firstly how the hell did the signal change from a all clear aspect to danger when the signal operator can see the train approaching it?
If the driver has clear aspect he is obviously going to be accelerating so there would be no way to stop for a sudden change like that when hes right on top of it
Secondly where is the loaction of the signal? does the location make it harder to judge the distance
EDIT: AD is Ashford code i believe
