2V76 Gatwick Airport - Reading running as 6 carriages
rdh-eld
24 Jul 2020
Redhill
Tonight, and what looks to be the last few nights, the 2129 GWR service from Gatwick to Reading, 2V76, couples to another unit before leaving Redhill (at 2147). It looked like saloon lighting was out on the rear unit, is this a common occurance now and does anyone know why this is done?
It’s shown in RTT gaining carriages at Redhill throughout the current timetable period up until December
PGAT
13 Apr 2022
Selhurst
The other unit is the final train of the day to terminate at Redhill. Presumably they join up as they don’t have drivers to run a separate service to Reading
rdh-eld
24 Jul 2020
Redhill
Looks like the other driver sits with the one to be towed, or at least seemed it earlier. If you check the running times it looks like it loses a fair bit of time which I'm assuming is as a result of it!
FGW_DID
23 Jun 2011
81D & 81E
Yep, standard occurrence and that's how its booked to run - rear unit locked out. Presumably its due to some of the platform lengths at the stops between Redhill & Reading being too short to accommodate the 6 so the rear 3 will be locked out.
Taunton
1 Aug 2013
Been going on for a long time. The Gomshall fatal level crossing accident report in 2004 commented obliquely how the foot crossing view of the opposite line was concealed by the three locked rear carriages of this last train of the day that the accident passengers had alighted from.
KT530
12 Jan 2013
The driver travels as passenger back to Reading on the train, so will be a case of no additional path being available or being needed.
The second unit won’t be “towed” - it will simply be out of public use, but otherwise working normally.
Deepgreen
12 Jun 2013
Gomshall, Surrey
I don't believe it would be "towed" as there is no reason for the units not to work in multiple. A unit won't be planned/diagrammed to haul another 'dead' one in service. The running times, at least to Guildford, look the same as other workings.
Yes. This freak accident (because 6 car trains are rare on the line) has resulted in the hideous and ludicrously OTT bridge at Gomshall, when a foot crossing gate locking mechanism and mandatory horn sounding would surely have been a simple and hugely cheaper solution to the very small risk.
rdh-eld
24 Jul 2020
Redhill
Yes sorry, bad wording from me, who still had the idea in my head of that unit being 'rescued' rather than it being an easy way to return a unit to Reading without needing an additional service!
Perhaps the last few days I'd looked had been bad days, but I saw a lot of late running on RTT. Plenty of factors which can affect that though.
