25/6.25 kV electrification removed
Strathclyder
12 Jun 2013
Clydebank
Further to the Strathclyde examples already mentioned, Dumbarton Central's platform 4 had it's track and pointwork, wires and posts removed in February 1992 as part of a resignalling project.
Ianigsy
12 May 2015
There was a long electrified siding where the new car park was built at Wakefield Westgate - never used to my knowledge but presumably put in to allow a Mark 4 set to be recessed there if needed.
Haywain
3 Feb 2013
A stretch of the ECML immediately west of Prestonpans station was moved south in the 2000s, with the original alignment abandoned and dewired.
50032
3 Mar 2016
Until a couple of years ago there was a few hundred yards of the CLC electrified to the east of Hunts Cross West Junction... not as far as Hunts Cross station but far enough to shunt an engine behind the protecting junction signals and for moves into the rear of Allerton depot (crossover now removed).
IIRC the wires now end at Hunts Cross West Junction (but no electric trains use the Hunts Cross Chord lines).
Beebman
17 Feb 2011
Twyford
I think this section was de-energised from nearer Allerton back in the 70s when the 3rd rail was extended to Hunts Cross in order to avoid return current conflicts between the two systems but it's only more recently that the wires have been removed. When it was AC electrified in the early 60s there was also a couple of hundred yards or so wired on the CLC line west of Hunts Cross West Jct, presumably ready for a possible extension to Liverpool Central.
d9009alycidon
22 Jun 2011
Eaglesham
Add Airdrie carraige sidings reduced from 4 to 1, Helensburgh C.S and Smithy Lye C.S.
The full extent of the old North Bank electrification is shown here
D6130
12 Jan 2021
West Yorkshire/Tuscany
Those diagrams confirm my memory that the Up Loop at Craigendoran used to be electrified prior to the 1986 rationalisation and resignalling.
50032
3 Mar 2016
Very interesting, thanks.
Greybeard33
18 Feb 2012
Greater Manchester
Indeed some old masts are still in place in the Merseyrail cutting west of Hunts Cross West Junction, including the anchor structure for the overrun.
When Allerton depot was re-electrified about ten years ago, to accommodate Northern's 319s, the track layout was altered and the eastern access to the depot from the CLC line was removed. The fourth (northernmost) track east of the junction was rewired so that AC trains in the depot can use it as a shunt neck, but there is now no connection to the adjacent Merseyrail bidirectional DC track, thereby avoiding issues of AC and DC return current in the same rails.
childwallblues
3 Jul 2014
Liverpool, UK
There is still a shunt line alongside the Merseyrail track were electric units usually 319s or 323s are kept.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Great detail, thanks for the link. If it has not already been mentioned, Airdrie was also reduced to the bay platform and just one through platform to Drumgelloch (double line through the station subsequently restored for the Bathgate link of course).
Was this due to subsidence affecting the original alignment?
It was, coal miming subsidence which required a speed restriction.
Merle Haggard
20 Oct 2019
Northampton
In the book L&Y Locomotives, it's stated that the loco was built in 1912, scrapped in 1920 and ran on the third rail and also on the Hotcombe Brook branch. If that's true, it would be dual voltage because the 3rd rail was 1200v and the Holcombe Brook branch (electrified 1913 - after the loco. was built) was at that time overhead 3500v (as stated in an earlier post). But not relevant to the original question.
Intercity91
28 Feb 2009
I could have been certain that lasted until the rebuilding of Leeds station, as a convenient place to stable sets with the limited capacity, but increasing number of services, of the time.
The Viaduct Line remained in daily use until closure as part of the Leeds First project. The ECS movement for the 07:20 ‘Yorkshire Pullman‘ service stood there every morning to allow for on board laying up. It also got used during station reconstruction works for shunting into the extended Platform 3 (now 6). It had to go through statutory closure notice before being removed from the network…
RyanOPlasty
9 Feb 2020
Nuneaton
It was third rail, de-electrified and run as a DMU service then converted to Tyne & Wear Metro with 1500v DC overhead line. It didn't formally close at any point beyond that required for conversion.
The Quayside Branch which ran from the North Tyneside loop had OLE in the yards at both ends, and was operated by a pair of NER ES1 locomotives. The tunnels were third rail. More information here
11 Jan 2015
If we’re looking at sidings does the Euston Down side carriage shed count? And what about the up engine line.
Elecman
31 Dec 2013
Lancashire
And the Platform 17-18 lines at Euston
Was the Rat hole ever wired?
