I have not done this before, no. I usually pay via contactless card. I read online that freedom pass usage history is stored on a persons record 8 weeks at a time. After 8 weeks, the history is no longer kept on an individual record. Also, if they do check usage history, how are they going to determine who the card was being used by at the time? How does the history of the journey determine identity- we live together so we would travel to and from the same address. Would this be something they would likely use to prosecute me? It seems a bit presumptuous.Have you accidentally done this before? I am sure they'll be checking the usage history - but I think it's quite important to establish from the outset if this really was an accident and a one-off.
Offering to pay after will make no difference to any defence, nor showing a record of your payment.
Also, regardless of the coat you were wearing - how could you remove another card and tap it without identifying the card first? Would you just tap anything you pulled out of your pocket? Was your contactless card loose in the pocket instead of a purse/wallet?
Hi thanks for your response, here is the relevant letterIf you’re able to share what TfL have sent you (make sure you hide your personal details so the whole web doesn’t get to see them!) that may help us to give better suggestions as we’ll know exactly what TfL think they are doing.
It is important that you engage with and reply to this letter. You might want to include the following in your reply:
- That you are sorry for what has happened
- What you have learned from the incident
- That you are keen to settle the matter without the need for court action
- Offer to pay the outstanding fare and the train company's administrative costs in dealing with the matter
Make sure your reply is short and concise, don't give a sob story - they've heard it all before.
Why would that matter? The officers caught the OP red handed tapping the freedom pass, which makes an alert on the gate.Did you tap in or tap out? Because if it was the latter then that means you should have proof that you tapped in with the contact less card.
It absolutely does matter, if they tapped in then it looks like they were fare evading but if they had tapped in with their contactless but then accidently tapped out with the freedom card then it shows it was a mistake as they intended to pay. Card clash is very common.Why would that matter? The officers caught the OP red handed tapping the freedom pass, which makes an alert on the gate.
After taking my details and removing the freedom pass, I asked the officer to let me back out so that I could tap my contactless card and re-enter.
This might be reasonable if they were kept in the same wallet (although the question about why the OP was carrying her mother's pass would persist) but otherwise it looks to TfL simply like trying to evade the fare. And TfL have a hard line on misuse of Freedom Passes.It absolutely does matter, if they tapped in then it looks like they were fare evading but if they had tapped in with their contactless but then accidently tapped out with the freedom card then it shows it was a mistake as they intended to pay. Card clash is very common.
I’m not sure whether I should plead guilty or not guilty, as I did in fact wrongfully tap the freedom pass, but I did not intend to do so, and upon being confronted with the mistake, I offered the pass up and paid the outstanding fare immediately.
The OP says they had to be “let out” to tap back in, so I was under the impression this stop occurred at the start of the journey.It absolutely does matter, if they tapped in then it looks like they were fare evading but if they had tapped in with their contactless but then accidently tapped out with the freedom card then it shows it was a mistake as they intended to pay. Card clash is very common.
The letter does not say, so I doubt the OP knows.We don’t know what offence the OP is being investigated for yet, so some more detail from the OP would be helpful here.
given the age one needs to be to be entitled to a freedom pass, I do wonder how many students would wear the coat of the owner of the freedom pass
This does appear to be their appetite, probably for simplicity.The letter does not say, so I doubt the OP knows.
However, memory says there have been previous cases on here where TfL have opted for the straightforward Byelaw route of not having a valid ticket rather than anything more serious.
Hi, it does ask me to admit fault. So is it best to admit guilty to an offence?Thanks for letting us see the letter.
As far as I can make out, TfL are still at the stage of gathering information. They have not yet told you if they will take you to court, or what they will charge you with if they do. So you don’t need to say whether or not you are guilty of anything.
Something else you also need to know is that TfL rarely offer the chance to settle out of court: so either they will prosecute, or they will take no further action. But that doesn’t mean that you shouldn’t try asking For a settlement!
So my suggestion would be that you should respond in much the way that @Hadders suggests in a number of other threads: here’s an example that I’ve taken from https://www.railforums.co.uk/thread...-report-on-me-need-advice.229057/post-5568420:
In this particular case, I’d suggest that you should also explain why you were borrowing your mum’s coat, and mention that as soon as you became aware of the problem you took steps to pay the fare you should have done with your contactless card.
I was tapping into piccadilly and starting my journey there. Upon realising I used the wrong card I asked the officer to let me out so I could begin my journey using the correct card.The OP says they had to be “let out” to tap back in, so I was under the impression this stop occurred at the start of the journey.
Hi there thanks for the reply.Welcome to the forum!
A few comments and observations:
The advice I give on what to include in a reply to the tyoe of letter you have received is linked to in one of the earlier replies so I won't repeat it again. TfL aren't noted for settling out of court but there is no harm in trying. Experience has shown that engaging with the process normally yields a better result.
- TfL take misuse of Freedom Passes seriously, if you haven't already done so you should tell your mum and TfL may get in touch with her and she could have her pass revoked
- TfL will look at the journey history of the Freedon Pass. They could link this up with CCTV to see who was travelling. I'm not saying they will do this but they could do this.
- You claim this is the first time this has happened but if, for example, the journey history shows that journeys are made regularly to Piccadilly Circus and TfL discover that you work nearby and that the times of the journeys match up with the times you start and finish work, this could present difficulties for you. I'm not saying that I don't believe you but simply pointing that if you have used the pass before it is better to tell them about it now rather than let them find out later
- Be aware that when you reply to the letter you have sent it is 'under caution', this is clearly stated in the letter TfL has sent you so you must be truthful in your reply to them
Feel free to post a draft of your reply in this thread and forum members will be happy to proof read. Do keep us updated on any further correspondence you receive and will will be happy to assist.
The misuse that they have already identified.what grounds would they need to investigate card usage history
Start of journey.We need @Aime to confirm exactly what happened but reading the original post it appears that this ws at the start of the journey as it mentions being let out and then tapping back in with a contactless card to continue the journey.
But how can they determine it was being misused and a mistake? I was entirely compliant and honest when I realised and actively pursued the payment of my journey.The misuse that they have already identified.
What does this mean? What is straightforward byelaw route?The letter does not say, so I doubt the OP knows.
I will post a write up of what I might send and would really appreciate if you proof read and just amended parts that won’t prove successful.Welcome to the forum!
Will this make a difference to how the issue is treated? Since I did actually pay for my fare?
Also what grounds would they need to investigate card usage history or CCTV footage and how can I avoid them from taking this action? What would I need to say in my statement.
Any help and advice is appreciated.
They asked me to submit any evidence I have. What type of evidence will stand in my favour?
Also on what grounds would they investigate into the above.
The letter I have been sent is so vague and I extremely confused by how to approach it. I will look at the link above for some advice and get back with any questions.
Does it make any difference that I actually did pay my fare on the day? Will providing evidence of that be sufficient?
You're right - it does ask you to deny or accept that you were committing an offence. Sorry for not having read the letter quite carefully enough!Hi, it does ask me to admit fault. So is it best to admit guilty to an offence?
What exactly does prosecute entail? That I would be jailed or have a criminal record? Or that I would be fined? The letter is extremely vague but it does ask me to admit to whether I am guilty or not.
Earlier that day I had walked my dog in the coat and continued on my day wearing it. Also my mum has a freedom pass for disability reasons not based on her age. So for those making comments about why I would wear her coat, i’m not sure what you’re suggesting from that, it’s not unheard of for mother and daughter to share clothes.
Another thing, they asked me to supply evidence in my favour. Shall I provide previous payments i’ve made via bank card? And the evidence of my paying the fare on the day? I’m not sure how to go about submitting evidence and what is good evidence and what is not.
It was used to tap in. That's all they need.But how can they determine it was being misused and a mistake? I was entirely compliant and honest when I realised and actively pursued the payment of my journey.
As much as they like. Criminal investigations wouldn't get very far if permission was needed to investigate.How much are they allowed to investigate without my knowledge? Aren’t they supposed to inform me on what they are investigating?
In the OP's defense I would say loads of reasons why they could have acted as they did and be totally honest in their character - if you have made a mistake of the sort the OP outlines.You originally said:
"I was involved in an incident where I accidentally tapped my mother’s freedom pass which was in the same coat pocket as my contactless card. The officer who stopped me asked me to hand over the card. I was hesitant to do so at first but upon realising my mistake, I offered the card over in attempt to rectify the situation. She then began quizzing me of my details and removed the card. I explained that the card was my Mother’s as was the coat I wore on that day, and asked them to give it back to me as there had been a mix up but they told me it will now be destroyed and the matter will be escalated. After taking my details and removing the freedom pass, I asked the officer to let me back out so that I could tap my contactless card and re-enter."
but now you suggest:
"I was tapping into piccadilly and starting my journey there. Upon realising I used the wrong card I asked the officer to let me out so I could begin my journey using the correct card."
Suggesting you realised the mistake yourself and went to ask to be let back out, which would be quite different. Especially when you also said originally that you were hesitant to hand over the card (which in itself suggests you knew you'd tapped the wrong card) and presumably got asked to show it before you'd gone over to voluntarily tell them of the mistake you'd made.
I would suggest you are honest on here if you want to be given help and advice.
"Upon realising I used the wrong card I asked the officer to let me out so I could begin my journey using the correct card."
"Hesitant to hand over the card"
This means to me they had got through the Piccadilly Circus barrier using mum's card by mistake, then was approached by staff, staff asked to see card, OP realised mistake, and asked to be allowed back to the 'non platform side / non ticket holder side of barrier line ' to start all over again with a correct payment card' - to me this is exactly what anyone who had made an honest mistake and wanted to 'out things right' would do. It's what I would do (of course to a ticket inspector used to dealing with fares evaders it is what a fare evader would do too - but an honest passenger would not think of that in the spur of the moment IMHO.
- explained by the fact that you have a mum who might need to use the card later that day - and giving it up to staff would make life much more complicated for the OP's mum. I can imagine lots of people being hesitant if they did not think they had made an intentional error.
Whilst @Aime (OP) needs to think how this looks to that staff on duty who spoke to her. We need to think how it seems to @Aime who juts thinks she made a simple mistake but now being threatened with court action.
I think @Aime should follow @Fawkes Cat very good advice on how to respond, and post draft response here for advice on the draft wording before sending it into to TfL
Also to @Aime we have seen a few cases on here in recent months where TfL have, on considering passenger's replies, issued a warning and taken no further action (either at court or request for further payment) - sorry I can't find them to link to at the moment as it would take a while to look - but that does mean that you have a chance of getting them to accept your explanation of the error you made, so maybe a decent chance to resolve this.
The thing is, how would they be able to determine WHO is frequently using the card? My mum makes a few regular trips weekly with her card, but in what way do they determine that’s her and not me since they are investigating me?In the OP's defense I would say loads of reasons why they could have acted as they did and be totally honest in their character - if you have made a mistake of the sort the OP outlines.
This means to me they had got through the Piccadilly Circus barrier using mum's card by mistake, then was approached by staff, staff asked to see card, OP realised mistake, and asked to be allowed back to the 'non platform side / non ticket holder side of barrier line ' to start all over again with a correct payment card - to me this is exactly what anyone who had made an honest mistake and wanted to 'put things right' would do. It's what I would do (of course to a ticket inspector used to dealing with fares evaders it is what a fare evader would do too - but an honest passenger would not think of that in the spur of the moment IMHO).
As @Haywain points out they have the evidence that allows them to take action and carry out further investigations if they choose to do so (eg to see if there are patterns of use of the freedom card that to them look suspicious - but if you have never used it by mistake or intentionally before then a good chance they will not find anything of that nature), but you need to try to persuade them that you made a simple mistake that will not happen again in the hope they accept that explanation and not take things any further.
