225 powered by 2 x Class 91s
13 Feb 2012
London N1
Apologies if this has been covered elsewhere.
I was wondering whether an IC225 set has ever been push-pulled by 2 Class 91s (in the same configuration as an IC125) and if so, what was the acceleration like? Could 225s be extended to 11 coaches using 2 91s? I realise this would create a surplus of Mk4s however. Just interested in operability.
I am aware that shortly after the introduction of the 225s, Class 43s (the ones fitted with buffers) were used as a powered DVT for the sets. Also aware of OHLE wave caused by front panto and potential for rear panto not contacting the OHLE.
Looking forward to my second trip of the year on a 225 this afternoon from KGX-DON.
jopsuk
13 May 2008
I think there's been some test runs in recent years using two 91s, as part of the research for the IEP.
As for 11 carriages? I've seen claims that's how long BR proposed making them. Kings Cross would have easily coped, I'd guess some stations might have problems. I'd have thought a longer formation might foul the crossovers at Edinburgh Waverly?
TrainBoy98
19 Mar 2012
Worthing
Not really related, but couldn't a 225 with 91 at the front have a 43 (with buffers) permanently attached as part of a set? Surely this would make the train bi-mode saving having them with IEP?
This happened with Mark 3 rakes prior to the Mark 4s arriving.
Unfortunately I have doubts about the performance of a single HST power car hauling an entire Mark 4+91 set.
And having to fit some sort of static converter rig in the HST's luggage compartment to support the loco style ETS.
Monty
12 Jun 2012
You could in theory I guess but I see two problems with that. A single class 43 may struggle to pull a 9-Car 225 set with a dead 91 in tow. Secondly where do you find spare Class 43 power cars from? Unless you build new stock (like the IEP) there will be no spare power cars to use in such a venture.
ryan125hst
2 Jun 2011
Retford
Presumably though, the second Class 91 would replace the DVT? If this was the case, you would need to add a luggage van and guards compartment to one of the Mark 4 passenger coaches, maybe in a way similar to the TGS in a HST.
As for 11 coaches, you would end up with less sets as there are only enough coaches for 30 sets at 9 coaches per set (and I think there are one or two spares), so they would end up with around 24 sets. East Coast currently use 27 per day, so they would need more stock from somewhere.
Out of interest, what formation would you like to see if they were made into 11 coaches?
370001
13 Feb 2012
London N1
To be honest I was interested more in operability rather than proposing a standard running configuration. I know the sums don't add up and there are physical constraints at some stations. I was simply curious if a set had ever been push-pulled by 2 91s and what the performance was like.
D365
29 Jun 2012
Weren't the 91s (+225+DVT) designed to be operated in formations of up to 11 cars? If a return was made to the 91 + Mk3/4 + 43 formation, the latter loco wouldn't be able to pull the set on its own - after all, 1+7-9 HST sets aren't possible. Although I would like to own a rake myself :D
sprinterguy
4 Mar 2010
Macclesfield
One of the later (1981) proposals for a production fleet of APTs envisaged a steamlined power car at either end sandwiching eleven passenger carriages, which would have been very similar to an 11-car IC225 with a 91 at each end. During the development of the IC225 project, it was initially (1986) stated that the IC225s would be formed of a class 91 loco, eleven passenger carriages and a DVT, although the length of the formation was cut back by the time that the trains were ordered due to lower passenger forecasts. Eleven carriages was decreed to be the maximum length of train that was possible with a single locomotive due to the propulsive forces that would be enacted on the carriage adjacent to the locomotive when in propelling mode.
1+7 and 1+8 HST formations can and have operated in extreme circumstances, however their rate of acceleration is obviously markedly slower than a "healthy" HST set and they have difficulty reaching and maintaining 125mph. This might be less of an issue on the sections of route where an HST power car would be expected to haul an IC225 set, as East Coast's off wires sections of route are generally slower than 125mph and no more than 100mph. Also, although admittedly it would probably be unfeasible to implement so late on in the HST power cars' lives, even at the time that the production HSTs were built a 3,000hp power unit was available that would fit into the HST power car bodyshell, although this would increase the axle weight.
GNER had a proposal to lengthen the 225 sets to ten carriages by adding an additional mark 4 carriage into 27 rakes, split from three existing sets. Three modified mark 3 sets would have been formed up to replace the disbanded mark 4 rakes.
Bridge189
19 Sep 2011
I'm sure its been mentioned that MK4s are nearly double the weight of MK3s so any proposal that an HST power car could push/pull a dead 91+ 9 MK4s up un wired sections is laughable. They can hardly manage push/pulling a one engine out EC HST with 9 coaches.
What?
Mark 3s come in at 35-40t each and Mark 4s come in at 40-45t... hardly double.
asylumxl
12 Feb 2009
Hiding in your shadow
The weight is not much different. The track access charges on the other hand are almost double for a MK4.
Bridge189
19 Sep 2011
I knew something was almost double!
Even the 10t weight difference and a dead 91 will still cause a single HST power car to struggle push/pulling them along. It's a total non starter idea, NR would have a fit.
sprinterguy
4 Mar 2010
Macclesfield
Absolutely, I never suggested that a single HST power car in it's present form would be capable of hauling an entire IC225 formation over, say, the formidable gradients of the Highland Main line. You are undoubtedly correct that the idea is a non-starter.
Bevan Price
22 Apr 2010
Would the "overhead" be capable of providing enough current for two 91's, especially if more than one train was in the area ?
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
I travelled on the southbound Chieftan with a failing power car. It started cutting out early on the journey on the climb up to Slochd. I seem to recall arriving into Edinburgh a few minutes late, but most of that delay was accounted for by a delay at Carrbridge.
See my remark above. I've travelled on other HST sets in service between Kings Cross and the North East with just one power car, and the loss of timetabled arrivals was more a consequence of failure to achieve 125mph than the more modest, though noticeable lower acceleration. Disregarding the error in asserting 'nearly double the weight', I've seen a northbound 225 set, in service, hauled by a 91 with another 91 DIT coupled immediately behind it - I cannot comment on its timetabling.
O L Leigh
20 Jan 2006
In the cab with the paper
There is no need to add another Cl91 to the IC225 formation. The single loco is man enough to handle the weight of the set and the timetable of the ECML. They are configured to work in a certain way and adding the additional power would not add anything.
O L Leigh
ffm
20 May 2012
Erm, what about the loss of trains this would cause? There are only 31 91s and always a couple in maintenance. So only 14 trains, or so. Whether it could be done, or not, is therefore completely immaterial.
D365
29 Jun 2012
2x 91 haulage is not needed. They were designed to haul up to 11 Mk4s, and more? There was a proposal by GNER a while back to split up a few rakes, give the stricken 91s and DVTs some Mk3s and lengthen the rest of the IC225s to 10 or 11 cars. Would put a lot more work on the locos though; perhaps 11 car IEP would be better if longer trains are an aspiration.
matchmaker
8 Mar 2009
Central Scotland
An HST with a failed power car is not allowed north of Blair Atholl without assistance.
ryan125hst
2 Jun 2011
Retford
What are the reasons for this? Is it because of steep gradients, so by having assistance prevents damage to the track or delays to other services?
sprinterguy
4 Mar 2010
Macclesfield
As far as I know it is due to the gradients; I thought that I could recall such a ruling, but wasn't entirely sure, so thanks to matchmaker for confirming it. I think that I remember reading that a class 37 has been turned out on at least one occasion to provide the necessary assistance, which in terms of power output seems to rather defy the point (Assuming that the entire HST formation would be being hauled "dead" as would be usual when an HST is being hauled).
GNER 91128
13 Jan 2011
Peterborough
I could imagine there being greater acceleration and breaking from having two 91s working together. Wouldn't the 225 be classed as an EMU if there were two 91s opperating together?
ryan125hst
2 Jun 2011
Retford
I doubt it. It is still two locomotives pulling/pushing a rake of passenger coaches. If Chiltern removed the DVT and added a second Class 67, could that be considered a multiple unit?
I think I understand why you think that though. Eurostars are EMU's, but are almost two locomotives hauling articulated coaches (although the coaches next to the locomotive do have motors, but at the end nearest to the power car only).
Yew
12 Mar 2011
HST's where originally classed as DMU's :D
D365
29 Jun 2012
It's somewhat of a difficult matter to judge? I imagine the situation with a 91+Mk4+91 formation would be quite similar to that with HSTs when they were introduced.
ryan125hst
2 Jun 2011
Retford
That's true. Wasn't it the fact that the locomotives, and possibly even the coaches, were often moved between sets, so the set numbers on the front were wrong, that caused them to be classed as locomotives and coaches?
With that, you do wonder where the line between loco + coaches and EMU or DMU lies. A multiple unit normally has traction equipment or engines, air compressors, motor alternators ect, distributed throughout the train. A HST has none of that, as the engine, motors, air compressor ect are all in the Class 43.
jopsuk
13 May 2008
I'll go with "no"- the Edinburgh - Glasgow shuttle, before the 47/7s and DBSOs, was operated by top-and-tail, working in multiple, class 27s. This was not counted as an MU formation.
GNER 91128
13 Jan 2011
Peterborough
Ah right okies.
