Noticed today 158783 had the mods which I presume makes it compliant to the rules applying in 2020. Retention toilets, door opening sounders and most obviously a new internal information system. This has obviously been done without trying to sort the various minor damages since the last refurbishment, such as replacing the missing hinge covers on the armrests.
The information system has two pairs of wide but shallow screens in each saloon, similar in size to the larger ones on the 700s. However I only saw two lines of yellow text on blue, so obviously much simpler software but very readable! At present the functionality leaves something to be desired:
- No display of next calling points while the train is in a station, until it starts moving when it's too late if you boarded the wrong one.
- Went blank on the approach to Nottingham, so perhaps conveying the complicated information about the train split there is too difficult.
I guess it might improve when the whole fleet is fitted, when I guess the displays on coupled units can be controlled from the same cab.
