Having seen a number of references to the problems with the 2012 West Coast Franchise award being due to a 'Spreadsheet Error' I thought, as someone involved in government modelling, I would clarify things a bit, explaining a bit about what happened in relation to 'the spreadsheet' and what has happened as a result.
This is, by the way, my own view and not necessarily that of my employers, the government etc.
First off, a link to the key report, the Laidlaw Inquiry report.
https://www.gov.uk/government/publications/report-of-the-laidlaw-inquiry
NOTE: Amended to correct my belief that the Ready Reckoner was 'the spreadsheet'.
If you read it you find that find that 'the problem' was not an 'error' in a Spreadsheet as most people conceive of it. The spreadsheet in question was used to produce a 'Ready Reckoner' supplied to the bidders. This was a tabular guide calibrated from detailed runs of the 'GSP Resilience Model' (GDPRM). Except that the runs of the GDPRM had been carried out incorrectly, so the numbers in the Ready Reckoner were wrong. The runs could have been done correctly but what the report describes as 'technical flaws and inconstancies' made it more likely that the mistakes that were made would be.
Of the many recommendations from Laidlaw only one refers to modelling.
The rest of the recommendations deal with a whole host of other problems - there wasn't one 'problem', there were many and the problem with the Ready Reckoner and the way the GDPM was used was a symptom of the other, more fundamental, problems.
The result of this, and other issues, was the MacPherson 'Review of quality assurance of government models'. The title of the report is a bit misleading in that it also looked at the 'QA' regarding how an otherwise high quality model was used. For example you might have a perfect model of your mortgage repayment plan but its not that useful if you put the wrong interest rate in or use it to predict your pools winnings.
https://www.gov.uk/government/uploa...ovt_analytical_models_final_report_040313.pdf
Its hard to summarise the results of this, but I think the key one is 'no need to panic' - there was no major cross-governmental issue with the QA of models. However it did recommend some standards etc. to be followed across government and create a 'one stop shop' for 'best practise'.
I build and use models for the MOD, working in the Policy and Capability Department of the Defence Science and Technology Laboratory. MacPherson has led to very few changes in the way we do things as, basically, we were following 'best practice' already. This doesn't mean we are complacent however. For example I spent, as a personal initiative, part of Friday afternoon writing code to make it easier to maintain the QA of some of our models.
I hope people found that interesting and useful and that it cleared up a few misconceptions.
8.14.3 formalised Quality Assurance procedures are established in respect of modelling, encompassing best practice, audit and other testing procedures at appropriate stages of procurements; and
