2 x 5 car SET on ECML
HWLad
21 Aug 2013
Hi Guys,
My question is will the Mark 3 Electrification Equipment, used on the East Coast Mainline (ECML), be able to support 2 5 car Hitachi Super Express Trains (SET) running in multiple at 125mph?
I ask this as the ECML electrification was designed to support the one pantograph of the Class 91 at 140mph. However, having been reading these forums for a while, it seems dual pantograph operation requires a speed restriction of 110mph (like when North of London Class 373 sets were used) owing to the oscillation of the wires. I'm curious as to whether these oscillations are acceptable for the SETs working in multiple at 125mph with current infrastructure or whether it would need improving as part of the InterCity Express Programme (IEP).
asylumxl
12 Feb 2009
Hiding in your shadow
As far as I am aware, testing has been done to ensure compatibility between the two pantographs and the OHLE on the ECML. There should be no issues.
D365
29 Jun 2012
As far as I remember, testing has taken place with two Class 91s coupled back-to-back between nine Mk4 coaches, i.e. one loco replacing the DVT. As with the Class 395, pantographs are fitted on both driving vehicles, which provides a feature of redundancy as well as the necessary clearance for multiple working. When two SET units are coupled the outermost pantographs are raised.
jopsuk
13 May 2008
This is a classic of the enthusiast "I'm worried. Have they even thought about (really obvious issue)?"
So yes, as other posters say, they've carried out an extensive test program using trains with two 91s to prove that it's fine.
HWLad
21 Aug 2013
That's probably true, I apologise for being rather dense about it! I guess I should have phrased it to emphasise the methods in clearing 2 pantograph operation. I really appreciate the information!
jopsuk
13 May 2008
I apologise for being a little curt- there's been a rash of people posting such things!
BestWestern
6 Feb 2011
You'd be surprised how many 'really obvious issues' appear to be overlooked at times!
Philip Phlopp
31 May 2015
Hi Guys,
As others have said, it's all been tried and tested.
The Eurostar issue is a little more complex as the pantographs were set up differently with a higher uplift force for the higher tensioned High Speed routes. IEP/SET will have its pantographs suited to the ECML's current tensioning.
Murph
16 Feb 2010
jonty14
3 Aug 2009
Rottweil Germany
So what! Stop having a go at enthusiasts. It is getting really annoying on this forum! Let enthusiasts ask a question without being put down all the time. Is this a forum only for professionals? I don't think so.
D365
29 Jun 2012
Just as long as you don't try suggesting that a Class 91 should be gutted and converted to a DVT...
Taunton
1 Aug 2013
This is a classic of the enthusiast "I'm worried. Have they even thought about (really obvious issue)?".
Ah yes. You mean like "I'm worried. Is the budget and timescale really enough for the GW electrification which has just been approved ..."
SpacePhoenix
18 Mar 2014
Given that the class 91/HST hybrids of the late eighties reportedly took off like a rocket, then performance with a pair of 91s must have been impressive indeed. :)
Were 225 sets always planned to be a class 91 at one end and a DVT or were they initially intended to have a class 91 at each end?
Murph
16 Feb 2010
Their cousin, the class 370 APT-P, had 2x 4000hp Bo-Bo, but that was for 2+12. Everything I've ever read about IC225 was that it was always to be a single class 91 & DVT, at least after it had been renamed from APT-U to IC225. I can't remember what the original proposed formation was for APT-U, and can't find the site which had the info right now.
sprinterguy
4 Mar 2010
Macclesfield
APT-U would have had a power car at each end, sandwiching ten non-articulated trailers (There may also have been a stretched 2+12 version). A smaller APT-S was also proposed, with a 125mph maximum speed, which would mimic the eventual formation of the 225s in having a power car at one end, nine passenger carriages and a DVT, although the carriages would have been articulated.
As you say, the Intercity 225 project always intended to operate with a single power car at one end, and a DVT at the other (though they were initially (1986) proposed to include up to eleven carriages).
This page has some handy graphics of the possible APT train lengths:
http://www.apt-p.com/APTConfigurations.htm
And the following image has been posted on the forum before, and seems to show some sort of interim, semi-articulated proposal for the APT-S formation:
http://www.traintesting.com/images/formations.JPG
Did they just model it in the test program, or was there a programme of real-world testing too? ;)
It was reported at the time that this actually happened in a series of overnight (I think) tests on the ECML, though the activities seem to have been pretty clandestine in terms of information reaching the public.
It wasn't just a case of sticking a 00 gauge class 91 on each end of someone's Hornby train set and saying "yep, that seems fine", wait, sorry, I think that's not the right sort of "modelling". :p
theageofthetra
27 May 2012
Beckenham
Out of interest was this test train the most powerful to operate on the ECML or does that accolade belong to those rented in Eurostar units?
Surely you must have meant to write two Class 91s with nine Mark4s between them?
