1S69 Failure Abington 9th September 2024
Deepgreen
12 Jun 2013
Gomshall, Surrey
The 390 has 3 main air compressors.
There is also an emergency coupler in each end should the rescue come from other than a 57. However again the working instructions mean an on call manager has to attend.
So it appears that the couplers can't readily be used because access cannot be gained owing to a failure of the mechanism. Requiring an on-call manager to attend is all very well unless the failure happens in a remote location and the time taken to get him or her there is excessive. Having a well-maintained, working coupling mechanism which can be used by the driver must surely be sensible? It cannot surely be satisfactory for a train to be stranded because the next train ahead or behind cannot attach to it (and, in the latter's case, is blocking access by a rescue loco anyway). The railway has been gradually painting itself into a corner with this issue - the real-life ability for trains to be rescued by others seems to be diminishing steadily.
Peter Mugridge
8 Apr 2010
Epsom
Everyone was questioning at the time the wisdom of removing most of the Thunderbird coverage as being a false economy.
I think their point has been well and truly made now...?
DaveyJones
12 Mar 2023
The Pendolino Coupler extension is air driven, if the other comments in the thread are correct, no maintenance regime or driver competence will get a coupler out with no air :).
An example of Virgin's vanity hurting the Pendolino fleet still.
Everyone was questioning at the time the wisdom off removing most of the Thunderbird coverage as being a false economy.
And yet last week for the failure outside Euston there was a 57 on standby, but no driver (or would have been out of hours, travelling from Crewe was it, or Carlisle).
Either way, it seems this incident was entirely down to the operator (with Alstom maybe implicated in the train failure).
Network Rail plans to install ETCS on the North WCML, giving bi-di functionality, but that must be a decade away.
Bikeman78
26 Apr 2018
Given that loss of air is a common reason for needing assistance, this sounds like an impressive design fail. I've lost count how many sprinters with an air leak or faulty compressor have been rescued by simply attaching another unit.
Dr Hoo
10 Nov 2015
Hope Valley
Was the apparent fact that a fault on one compressor knocks out the other two compressors also part of the original design philosophy? Or was the train running around with the two other compressors already failed so that when the ‘last man standing’ went ping, that was game over?
Should there perhaps be a driver-operated foot pump, purely to extend the coupler in the last resort?
GLC
21 Nov 2018
The fitment of foot operated bellows would require an additional new technology uplift in pay for every driver though
tpjm
25 Jan 2019
The North
No time Limit to rectify a fault? We are given 10 minute timeline. After 10 minutes, all resources are used for evacuation and preparation for dragging the failed unit away. The rescue train is also called out after these 10 minutes.
Resources are mobilised within 10 mins, but given the remote location, take time to get to site. The call to DRS to stand up the Class 57 Thunderbird is one of the first things AWC Control do when a unit is stood.
You'd think so, but I'm told DfT are pushing for less Thunderbird coverage! DRS have been unable to resource the Rugby TB for some time now, but the 57s are on borrowed time!
You can get a coupler out without the Pendo having a working compressor.
Efini92
14 Dec 2016
Every single traction I sign has some kind of mechanical backup to open the front and extend the couplers. It is usually a very awkward and slow process which is probably fun to watch, but not to execute.
390’s have a staubli connection so the assisting loco can supply the air to the coupler.
deltic
8 Feb 2010
Are additional staff needed for a train to train transfer? And if so why given the number of staff already on board?
tpjm
25 Jan 2019
The North
Providing the pendo still has sufficient air.
I was more thinking about the assisting loco
Yes. Not all staff on board will be PTS trained, and train to train is rarely as straight forward as throwing a ramp out between two units. Consider customers climbing down a ladder, walking across ballast and back up into another unit.
QueensCurve
22 Dec 2014
The "decision" probably didn't take that long but getting all the resources to manage a controlled evacuation in time (even if train-to-train) undoubtedly took longer.
This is why bidirectional signaling, while seen as an unaffordable lucure, is actually essential. As soon as the decition was taken things could have been moving straight away.
Avanti 1S69 failure ongoing at Abington this evening. Queue of trains trapped in the rear. These 390s seem to be dropping like flies these days
Which is disappointing. Considering the sets have distributed power, one might expect there to be enough redundancy and diversity for them to keep moving. Is there any review into the failures with a view to preventing them?
Indeed, and if I had a pound for every incident in which full WCML bi-di signalling would have made a massive difference to the delays incurred I would be richer than Elon Musk.....
Me too.
I remember a breakdown at exactly this point in the 1970s, on the north side of the climb to Beattock.
The long, steep, climb makes this a black spot for failures. Even if only the bank was bidirectionally signalled it would improve things significanly.
muz379
23 Jan 2014
No doubt any incident which causes significant delay to be attributed to set failure will be investigated and any measures that can be put in place to prevent reoccurance will be . But that kind of stuff generally wont make it to the public domain .
Efini92
14 Dec 2016
I believe it was a power supply issue to the compressors that caused the failure, not the compressors themselves.
AndrewE
9 Nov 2015
but isn't that something else which would be "distributed?" i.e. each compressor would have a software-controlled switch off a main power bus. So more likely a software faut in the equipment sending a "compressors on" message than a loss of power to an actual power line running to the compressors the length of the train.
Efini92
14 Dec 2016
I’m not sure, we were talking about it this morning and it was mentioned there was an issue with batteries not charging.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
I attended many such reviews, into all sorts of massively disruptive events on the WCML in Scotland, and every time made the point regarding bi-directional signalling. Difference made it none.
SansHache
31 Mar 2015
Manchester
The Class 390 trains are very effective at self-recovery, hence the reason why Virgin got rid of most of their Thunderbird locos more than 10 years ago. However, there are vulnerabilities, mostly related to the air system and the 25kV distribution circuits.
On most occasions when there is a major failure such as this, it is a combination of events that coincide to prevent the train being able to continue to limp along.
All systems have redundancy built-in, but if a train is already in a degraded condition it may not be effective.
If a train has a major air leak then there is not a lot you can do to keep it on the move. The trains were originally designed to be able to couple to rescue another failed unit, but you are then left with the problem of what do you do with a 500m length train with more than 1000 passengers on board.
The important lesson is to learn from such incidents and to ensure that the possibility of them repeating is minimised.
Efini92
14 Dec 2016
so how does that fit with post #68?
I don’t think foot operated bellows would’ve helped ;)
I think that’s what the power supply issue was, there was no power from the batteries. Will wait and see what comes out.
Toby268
13 Jan 2022
Speaking of things repeating themselves. Another 390 failed outside of Euston this evening with a loss of line light again. Thankfully it managed to set back. Service cancelled and passengers on buses from Preston.
AndrewE
9 Nov 2015
sorry, typo for #78. I'm surprised that an EMU with live wires overhead is stopped in its tracks by a battery issue which stops the compressors working. At least a foot pump would have got the pan up and you would think that then the mains would be able to power the compressors.
Efini92
14 Dec 2016
I did think you were joking at first :D
The compressors aren’t fed directly from the 25kv. I’m not sure if they are fed direct from the auxiliary converters or from batteries. I will dig out the manual and have a look.
SansHache
31 Mar 2015
Manchester
Hopefully not a repeat of the incident that affected 390117 at Camden on Sunday 31st August. The train had just departed Euston when the OLE tripped and it was stranded in the dead section. The driver of another train reported a flash from the OLE near Primrose Hill tunnel and a "passer by" reported the wires were flapping in the wind. Four and a half hours later the OLE was re-energised as no evidence of any damage had been found. The train set off under its own power five hours after it came to a stand and the line reopened at line speed. Possibly a very expensive incinerated pigeon?
Horizon22
Jobs & Careers
8 Sep 2019
I doubt nothing specific happened considering it was 4.5 hours later.
SansHache
31 Mar 2015
Manchester
The three compressors are powered by 400V 3-phase supplies from three different Auxiliary Converters.
There is also an Auxiliary Compressor operated from the 110V battery supply to raise the local pantograph and close the VCB when initially powering up the train. However, at least one of the main compressors has to operate to charge the train air supply to release the brakes
