1F39 Avanti Euston - Liverpool Lime St. - Why set-down only after Milton Keynes
Grumpy Git
13 Oct 2019
The Avanti 1F39 service would be an ideal 'last train home' when attempting to connect at Crewe for getting back to Liverpool as it leaves at 00:09, (actual last train for Liverpool is the 1F74 WMT, which departs Crewe at 22:32).
Why is it set-down only after MKC?
Anyone needing to get from Crewe to Manchester can depart as late as 00:44, so why not to Liverpool when there is a train running there?
Class 170101
1 Mar 2014
I guess its because it can be diverted via alternative routes and omit some stations, run later etc.
Tetchytyke
12 Sep 2013
Isle of Man
So it can divert via different routes or run early if required. The very late LNER services are set down only north of York for the same reason.
This morning it arrived at Crewe 8 minutes early, and because it is set down only it didn’t need need to wait time.
The 0044 is a Northern service only calling at the airport.
frodshamfella
25 Sep 2010
Frodsham
It would be handy for very late passengers for sure.
357
12 Nov 2018
I have been on a train that left KGX around 22:30 that was set down only all the way to Leeds! Got in over half an hour early :)
Kite159
27 Jan 2014
West of Andover
Also means if it gets cancelled (or part cancelled) they only need to run replacement buses to the stations it calls at if there are passengers on board
_toommm_
8 Jul 2017
South West London
That’s the 23:33. Great train as it gets in half an hour early so connects well with the last bus from Leeds at 02:30 towards Headingley.
357
12 Nov 2018
There is one before that too! Or at least there was on this day. Taken from my Rail Miles:
London Kings Cross (p1) to
Leeds (p12)​
Service Information​
Departed on 13 August 2023 at 22:34, arrived on 14 August 2023 at 00:40.
Route: Direct
Service was operated by 800111.
greatkingrat
20 Jan 2011
In practice, I doubt there would be an issue if you did board that train at Crewe, although you would need to allow plenty of time due to possible early running.
QJ
5 Mar 2009
Basingstoke Down Yard
Set down stops can be omitted.
In theory should you get on at a set down only stop you could be charged the fare from the last pick up stop. I have been challenged once or twice after getting on at a set down only stop. An all line rover got me out of those situations.
I believe the early arrival at Leeds resulted from those trains being diverted away from it’s booked route via Knottingley (when there is no engineering work taking place). At least that was the reason when I’ve travelled on them.
greyman42
14 Aug 2017
I don't know about other operators, but LNER seem to be pretty relaxed about it.
357
12 Nov 2018
I'm not sure where we were supposed to be routed but in my case we got gradually earlier and earlier all the way
greyman42
14 Aug 2017
The 2300 Kings Cross to York is set down only for every stop. It often arrives early in York due to allowances for engineering that are not needed. It does not divert.
dk1
2 Oct 2009
East Anglia
Our last Liverpool St to Norwich trains were set down only back in the day. That’s the stuff of dreams to me and most of us now. Must’ve been wonderful days.
185
29 Aug 2010
There was an instance last month where Avanti had a number three services diverted off one line, and they refused to stop at alternatives on the diversion line.
Believe the ORR is now looking at the matter, with a view to reminding Avanti's directors that their focus should not only be on passengers from London, but in the communities they serve on the way, who are often reliant on Avanti as the sole operator at certain times of day. Running 90% empty, 600 seat trains, at 5mph through two major stations whilst 60-70 passengers are being pushed into 12-seater transit minibuses hardly does any good for the joined-up-railway's image.
What stations where they going through at 5mph?
Earlestown possibly? Though dispatching a Pendo from there would be an absolute nightmare.
Why would Avanti stop at Earlestown? what was the diversion, just round the houses via Newton le Willows and back on at Golborne?
185143
3 Mar 2013
They have and do run that way when Runcorn is shut and they divert via Warrington. That was the only available route when RMT signallers were out on strike.
I'm not seriously suggesting they would stop at Earlestown, merely it was the first diversion that sprung to mind with a very low linespeed. Middlewich is another, but that doesn't miss any stations out. That one's so slow the replacement bus between Crewe and Chester is quicker!
185
29 Aug 2010
Cant see the post 18 reply due to ignore, but it certainly wasn't Earlestown ...twas a major one as was stated in my post. Once complete I may post the outcome on here in a few days but there's a good reason why I won't yet.
Needless to say, it's happened before and there was the same process of complaint, then a report to the grown ups.... then an agreement to stop doing it, 12 months passes and now we're back to square one again, like some temporal loop in Star Trek where they deny knowing anything about the previous shenanigans.
david l
27 Dec 2016
Wigan
Wouldn't like to have been travelling last night from Euston to Warrington or Wigan. 21.10 (last train) was an hour down, stopped at usual stops as far as Crewe, but then seems to have omitted to stop at Warrington BQ and Wigan NW but still passing through there en route to Preston. Train before is 20.33 ex-Euston , once again (has been many times of late) cancelled so last train would have been 19.30 Eus-GLC.......
Dr Hoo
10 Nov 2015
Hope Valley
Are those stops ‘set down only’ or was it a case of needing to get to Preston before a block there or crew out of hours?
185143
3 Mar 2013
Usually the fact that WBQ+WGN close after the passage of the last train, and presumably station staff were (with no criticism of them!) Unwilling to do the necessary overtime to allow the train to call. Preston and Crewe will be staffed all night due to the Sleeper calling.
david l
27 Dec 2016
Wigan
No, full stops, no block.
Last Liverpool-Blackpool was also cancelled (due WNW 00.04) although as per usual ran ECS so presume no conductor. Perhaps the staff had already gone home...........
Edsmith
21 Dec 2021
Staplehurst
No there shouldn't be any problem although you obviously run the risk of the train not turning up if it's been diverted etc.
