195s truly awful, not a step forward
I think showing a more useful connections list is probably a big "curation" job on something as complex as Northern, so just showing a departure display probably makes most sense.
It really wouldn't be that difficult to filter out 'nonsensical' trains. It would just take a bit of care and effort - something which it's painfully obvious is lacking on the 195s.
It would be more complex given that you have to consider stopping patterns etc. Even SBB and DB I think just show a departure list.
If we had a Takt so you could just filter out all S2s or RE5s or whatever it's be easy, but as it is it very much isn't.
py_megapixel
5 Nov 2018
Northern England
One thing I do find extremely poor is that for stations with short platforms, the announcement just says "Please follow the instructions on the information screens", regardless of whether the coach you are in is going to open or not. That is incredibly bad, since an important function of the automated announcements is to assist the blind or partially sighted.
On every other SDO-equipped train I can think of, it says "Please move forward to leave the train" in the coaches which are locked out. On 185s, it's very clever: it says that in each coach sequentially, starting from the back, which means that if you start moving when the announcement tells you to and walk fairly briskly, you will keep hearing "Please move forward" until you're in the right place. (Not sure if that's the purpose, or if it's just because the system can only do one announcement at once across the entire train, but even if it's the latter, it still makes sense to start from the back as passengers at the back will need the most time to move forward).
Overall though, I quite like the PIS on the Civities. Apart from the SDO issue, it is a step up from anything else in the country except the Desiros that have proper screens (700, 717, 185 and now 350)
AM9
13 May 2014
St Albans
Given that those 'proper screens' have been in service for over 5 years, would it not be appropriate for a standard to be established across all coaching stock, certainly from delivery and for refreshes and refurbishments to all but the most 'razor blade ready' classes. The PIS is just a computer driven display using data that is for the most part, available on all modern stock.
jonnyfan
6 Apr 2013
Manchester
That's not quite correct, the PIS screens and announcements for short platforms only play in the carriages not accommodated, with the normal next station announcements in the other carriages - all of these happen at the same time. Unless there is some kind of fault. However if one door on a carriage is staying locked out then that whole carriage will receive a short platform announcement.
py_megapixel
5 Nov 2018
Northern England
If that's the case then it suggests the computer system is capable of making different announcements in different sections of the train.. so why can't it be more specific? At the very least, it could say the doors in this coach will not open, not just a generic not every door will open.
In the early days, it was definitely making the short platform announcements in coaches where the doors did subsequently open, but I think that may have been a bug that was later fixed.
At risk of sounding like a cliche - I'm sure that would make sense, which means it will never happen.
skyhigh
14 Sep 2014
Are you sure it doesn't say that? I can't remember the exact wording having not heard it for months, but I thought it did say something along those lines.
py_megapixel
5 Nov 2018
Northern England
Not heard it for a while either to be fair. But I thought it just said follow the instructions on the screens for information on which doors will be available for use.
It's possible they may have updated it, in which case good on them for implementing a simple yet worthwhile improvement.
ac6000cw
10 May 2014
Cambridge, UK
I recently spent a day on sampling as many different MUs around the Manchester area as I could, including several 150s, a 175, a 185, several 195s, a 331, a 769 and a Voyager.
I thought the 331 and the 195s were quite pleasant inside - nice big windows and typical modern seating (a bit hard but OK), ride was a bit lively but OK (again, not untypical of some modern trains). The 195s seemed reasonably quiet for an underfloor engined DMU, gear changes were smooth and acceleration good.
Best-riding train of the day was probably the 769 (I was in the front carriage), followed by the 185 then 175, 150 and Voyager.
Noisiest train of the day was the 769 on diesel - quite 'boomy' engine noise where I was sitting (towards the rear of the front carriage). It's interesting that it was fairly quiet from the outside.
Russel
30 Jun 2022
Lichfield
I must be in the minority; I've done a fair few journeys on the 195s now and can't say I have any real issues with them.
Okay, they are a bit characterless but they do what they are designed to do.
Killingworth
30 May 2018
Sheffield
You're not in the minority. Anyone who regularly had to travel on Pacers and now uses 195s would find them truly brilliant. Obviously opinions must vary but truly awful is a very harsh judgement. I speak as a regular standee by choice rather than one who previously had to be a sardine!
YorkshireBear
23 Jul 2010
I find them very acceptable and enjoy them a lot more than the 150s, 156s and 155s. 158s and 170s are better though.
Rhydgaled
25 Nov 2010
No it isn't a harsh judgement at all. They are truly awful - not because of anything that is actually particularly wrong about them but because they were built about 15 years too late. By the time they entered service, the Government had set an ambition to take all diesel-only trains off the track by 2040. Given 35 years in service some class 195s will still be with us in 2055, to make 2040 they would have had to have entered service in 2005, or in 2015 for life-expiry in 2050.
py_megapixel
5 Nov 2018
Northern England
So shall we go back to Pacers then?
Rhydgaled
25 Nov 2010
No; the CAF Civity units should have been future-proofed with electric traction (bi-mode, although if the Northern Pacers were used on similar routes to the Welsh Pacers (ValleyLines) then really they should have been electrified by 2020 meaning only 331s would have been needed and no 195s and we wouldn't be having this conversation).
tomuk
15 May 2010
Who would have paid for that, though? It was not a requirement of the franchise bid, so a bidder including it would have priced themselves out of contention in their fleet strategy.
Quite, the Transport secretary at the the time had to formally overrule his civil servants to 'waste money' by including a requirement to just replace the Pacers in the franchise agreement.
Rhydgaled
25 Nov 2010
It shouldn't have needed to be a requirement in the franchise bid - it should have been illegal to place orders for brand new trains that did not have OLE compatibility (or passive provision for it) since about 2010. After all, sales of new petrol and diesel cars are going to be banned; an equivalent is needed in the rail industry.
They'll still have a use in 30 years or so
That is the problem. They will in all likelyhood still be in use in 30 years time, but they shouldn't be. As the topic title says, the class 195s are "not a step forward" at a time when we need to be making massive strides forward.
tomuk
15 May 2010
So TfW couldn't of ordered your hated 197s?
Razorblades
17 Dec 2021
Copshaw Holm, Scottish Borders
You're speaking entirely hypothetically. Those of us engaged in real-world railway activity at the time (2014-15 Northern bid) could only play the hand of cards we were dealt. Airy-fairy idealism is just that, eight years on.
Rhydgaled
25 Nov 2010
And Northern couldn't have ordered the 195s, West Midlands Trains couldn't have ordered the 196s and Eversholt wouldn't be able to go ahead with their planned order for 10 hydrogen Aventras unless they can easily have a pantograph added.
Decarbonisation isn't idealism, it's essential. And the extent of electrification recommended by Network Rail's decarbonisation strategy would make a pantograph (or 3rd rail compatiblity) mandatory for virtually the entire fleet. If we are where we should be in electrification terms by 2050 the only units that could get by without would be:
  • Thames Valley branches (DCBMU) - 4 diagrams
  • Cornish Branches (DCBMU) - 5 diagrams
  • Wrexham Central - Bidston (DCBMU) - 4 diagrams
Plus maybe:
  • Bishop Auckland and Whitby branches (DCBMU) - 5 diagrams
  • Conwy Valley line (DCBMU) - 1 or 2 diagrams
  • Ebbw Vale line (DCBMU) - 5 diagrams
  • Bittern Line, Wherry Lines and Ipswich-Lowestoft (HFCMU) - 15 diagrams
That adds up to just 40 diagrams across the whole of Great Britain that hardly if ever spend much time under the wires. Take away most of the 'maybes' and you're left with just 15 diagrams, that's only about 25% availability from the fleet of 58 class 195s.
And the acronyms I just made up:
DCBMU = battery unit with Dedicated Charging facilities (rather than charging using electrification infrustructure)
HFCMU = Hydrogen Fuel Cell Multiple Unit
tomuk
15 May 2010
These should be electrified there is no need for dedicated battery stock.
Possibly but would the Cornish mainline be electrified by then? Should it not be a common pool of BeMUs not a dedicated ones for the branches?
This will be part of MerseyRail by then with 3rd rail electrification to at least Upton.
Plus maybe:
Whatever TfW are running on the coast
Whatever TfW are running in the south I'd suggest it will be electrified using the Stadller 231s\756s possibly with the diesel power pack replaced by a diesel one.
Same as above they have already got the Stadlers, bit of extra electrification plus battery power pack instead of diesel.
silicagel
5 Dec 2019
Plymouth
In the absence of reading the entire thread, I have to agree I do not like the 195s and would actually rather have a 142. Make of that what you will.
The 195s to me seem like just another pacer albeit even more cheaply made. An absolutely terrible unit for something brand new. Even 150s are better.
Agent_Squash
22 Jul 2016
How on earth is a 142 even comparable to a 195? Would be interesting to hear your thoughts other than just about how it feels cheaply made.
Neptune
29 May 2018
Plus maybe:
Crikey we haven’t had one of these rants for a while. Thought it was too good to be true.
AM9
13 May 2014
St Albans
For the record, that's your opinion, not a demonstrable fact.
As each year of unprecedented extreme weather demonstrates accelerating climate change, I find it disappointing that so many still dismiss it as an "opinion".
Razorblades
17 Dec 2021
Opinion is defined as 'a statement of advice by an expert on a professional matter' (source, Oxford Languages), and on the basis that expert opinions differ on the topic of climate change, it's hardly dismissing it.
AM9
13 May 2014
St Albans
That is a definition of 'opinion'. The Oxford dictionary's first definition of the word is:
"a view or judgement formed about something, not necessarily based on fact or knowledge."
That, in my opinion is the primary definition of the word for everyday use rather than a secondary one chosen to support a specific argument. Unless of course in your opinion the Oxford Dictionary has got it wrong!
