1938 LMS WTT Letters Explanation
Andy873
23 Mar 2017
I've got a small section of an LMS WTT (well I think that's what it is) from 1938. Can anyone tell me please what the following letters mean:
S, T, E, XS, TC. in relation to individual train journeys.
pdeaves
14 Sep 2014
Gateway to the South West
Are you able to put up images showing these letters? Context may help.
Northampton
Are the timetables from around that period on Timetable world? https://timetableworld.com/ They may have cover sheets available that might explain it.
Otherwise any ad-hoc annotations are usually described in the same or a nearby column, or in a footnote.
However, putting the full context of the relevant pages up will help other members decipher it fairly quickly.
Andy873
23 Mar 2017
I've attached one of the pages so everyone can see what I'm asking better.
hexagon789
2 Sep 2016
S is likely Saturdays Only
E is likely Saturdays Excepted
TC is Through Carriages
X and T would require the notes to decipher I suspect, as I don't think they are standard "symbols"
TC is almost certainly 'Train Continues' on another Table. Not sure on the others.
Through Carriages I would think.
Andy873
23 Mar 2017
Well, thanks everyone, I found the missing page, which does indeed explain these letters and more, See attached.
Rescars
25 May 2021
Good that you've found the key. Some of those letters and symbols would take a lot of guessing. Intruiguing that there are two different form of "s" denoting "Sats only".
Presumably some of these letters and symbols would have had the same meaning across all LMS timetables, but others are geographically specific. Did these reappear with different meanings in other timetables? If so, I wonder which letter or symbol was repeated most often and had the most different meanings.
Andy873
23 Mar 2017
That's a good question!
I had a look on Timetableworld and found another LMS one, this time a public passenger timetable. Some of the letter now denote different things... If you look at table 187 (page 410 - page numbers at the bottom of the pages), you can see what I mean:
LMS July 1939 - Timetableworld
Gloster
4 Sep 2020
Up the creek
I think that this is a public timetable covering only passenger train, not a WTT (Working Timetable, the internal one used by staff). The only entries are for stations, whereas a WTT would have a number of signalboxes, junctions and yards. All the trains appear to be passenger ones: no empty coaching stock, parcels, engine movements or even goods trains.
AndrewE
9 Nov 2015
it looks remarkably like a page from my facsimile pre-war Bradshaw's... (1922?)
28 Nov 2021
Leith
Interesting that someone felt the need to distinguish "Stansfield Hall, Todmorden" from any other Stansfield Hall, but not to clarify Portmouth or Mill Hill
Sir Felix Pole
21 Oct 2012
Wilmslow
I guess that this was to indicate that it was the station for Todmorden on Burnley - Halifax / Bradford services which avoided the main Todmorden station. By 1938 it looks as if it had hardly any trains, and indeed closed in 1944.
