185151 damage
alexl92
12 Oct 2014
Got on this between Huddersfield and Leeds today; coach C (First class) was leading and I noticed that the front end between the windscreen and the coupler had a large indentation and some paint missing. Anyone know how this damage was sustained?
Also, why are the 185s numbered in the 185101-151 series and not 185001-051?
IanM
20 Aug 2013
I think you'll find that the indentation is at roughly the height that someone's head would have been had they been standing on the track when a train approached.
ash39
8 Feb 2012
185118 has been running round in a similar state for the past few weeks. It may be repaired by now but wasn't as of last weekend.
185118 Garforth 14/02/2015
by Flash_3939, on Flickr
I believe the numbering is to do with the carriage numbers clashing with diesel locomotive numbers but I may be wrong.
XCTurbostar
13 Sep 2014
I would be very surprised if a person made that damage. It looks like something very heavy has caused it.
Thanks,
Ross
fowler9
29 Oct 2013
Thanks,
Ross
I don't agree. I think, very sadly, a persons head could have done that easily if the train was going even moderately fast. That will be part of a crumple zone I guess. If something very heavy did it the train was hardly moving and neither was the very heavy thing.
TheEdge
29 Nov 2012
Norwich
I saw the left hand light cluster and cab side of a GA DVT somewhat caved in and backwards after hitting a person.
Even hitting a bird can break a light cluster, plastic or a window.
455driver
10 May 2010
Thanks,
Ross
Have you actually seen what happens to the front of a train doing a decent speed when it hits a person?
Juniper Driver
17 Jul 2007
SWR Metals
When I had my fatality it damaged something on the compressor line and also opened a dump cock.Same at Surbiton when I went to assist a train involved in a fatality.(Had to take the two Bournemouth drivers off,one was route learning)...and took the train to Waterloo.
Also when I worked at Ilford as a cleaner many years ago a slammer class 302 came in which I guess had been in a fatality (they didn't tell us) and the wooden stepboard had been split/damaged.
VP185
13 Feb 2010
When I had my fatality the lifeguard was pushed that far back it was virtually touching the leading wheel.
XCTurbostar
13 Sep 2014
Hey, I didn't say it in spite. Last time I checked, it wasn't a good thing to have witnessed..
You've all made your points and I thank you all for correcting me ;)
Thanks,
Ross
