nmbenson
- Joined
- 12 Apr 2013
- Messages
- 16
Until a few weeks ago, 170s were a common sight west of Selby towards LEEDS but the services appear to have reverted to 15n series. Have the 170s been withdrawn or just reallocated?
Plenty on that line, the majority of work is booked 170s.There are still some on the Harrogate line
Still very much in service on the Scarborough-Sheffields and Harrogate Loop. One can drop on the Hull-Halifax or Hull-York services from time to time however as a way of getting units from Neville Hill to Hull and vice versa and between Hull and Harrogate duties (so I believe).Until a few weeks ago, 170s were a common sight west of Selby towards LEEDS but the services appear to have reverted to 15n series. Have the 170s been withdrawn or just reallocated?
They couldn't get route cleared through one of the tunnels (possibly Winterbutlee) between Walsden and Littleborough and also TPEs new trains were in the same boat whilst on diversion. The tunnel has since been fixed but northerns plans had changed by thenThey were originally meant to work Leeds- Wigan/ Southport- why was this dropped?
All full day York diagrams, just the peak 150 that runs twice a day. Normally 170s with the odd 150/158 on the Harrogates and Knaresboroughs.Plenty on that line, the majority of work is booked 170s.
Train Crew knowledge and all the units are used up on the current routesHow come the route coverage is still very limited for Northern's 170s?
SCA-SHF services aren't running at the moment, the service is split at Hull. Passengers have to change there with a connection time of just 2-3 minutes, the paths remain the same. I hope that they are holding the connections.They run every Scarborough to Sheffield service, and some York to Hull/Leeds (via CHF) services, though York to Hull is mostly 155s and York to Leeds/Blackpool is mainly 158s and 195s.
The 0655 Sheffield to Hull has changed to a 158 since Monday.SCA-SHF services aren't running at the moment, the service is split at Hull. Passengers have to change there with a connection time of just 2-3 minutes, the paths remain the same. I hope that they are holding the connections.
With it the 05:16 Hull-Sheffield appears to have done the same. Been the same unit since Tuesday for good measure.The 0655 Sheffield to Hull has changed to a 158 since Monday.
