158 820 "Damien"...Any workings gen?
Broken Viking
23 Oct 2006
some place west of France
Hail all! <D
Just a quick one for those down in ATW land. As mentioned elsewhere I'm nipping off to Newport on Friday, and I'm hoping that I might be able to work Damien into part of my journey, if I'm lucky with the workings over the weekend! <D
To this end; I'm not experienced enough yet to know if specific units are assigned to specific workings in advance, but if that is the case, does anyone know if Damien'll be working any services between Bristol TM/Pkway and Newport on Friday and the following Monday? If so, which ones is 'e booked on? 8)
Farewell for now, and cheers in advance for any gen! <D
>> Death <<
thefab444
27 Oct 2006
The New Forest
:| Given that 158820 is an ATW unit, why would it be working on FGW services between Bristol Parkway/Temple Meads and Newport?
Broken Viking
23 Oct 2006
Oh gumpf! I'd always thought ATW had the runs from Bristol TM through the Severn Tunnel...Otherwise why else have I seen so many ATW units at Bristol TM before? :shock:
In that case I suppose I can always take an FGW unit to Severn Tunnel Jct and change there for whatever comes (I presume ATW cover the workings between STJ and Cheltnham?) but given that the Bristol/Severn area is well outside the scope of my local knowlege, I suppose I could be forgiven for making that mistake! :)
westcoaster
4 Dec 2006
DTOS A or B
Death i do not think ATW use the 158's in south wales, i think they use 150/2's between cheltenham and newport.
I think the 158's are used on mid wales/birmingham/manchester/north wales services.
* just looked on fotopic there are pics of damien at seven tunnel junction this year so there may be workings.
Failed Unit
26 Jan 2009
Central Belt
There are still some 158's show up in South Wales, I have seen them on the Cheltenham - Cardiff route. The will also sometimes show up on the Holyhead - Cardiff and Manchester - South Wales route vice a 175. I am sure some are stil diagrammed to Cardiff as they can't do some of the exams they need at Machnellyth (sorry about spelling)
DJC_158
20 Sep 2006
Melksham
there also has been i believe 2 ATW 150 units that have been on hire to FGW too which may account for seeing some of their units in the Bristol TM
HSTfan!!!
11 Jun 2005
the 158's still get used right across the atw network, not so much the valleys but I've even had the pleasure of a 158 from barry island in the past...!
And the reason you've seen atw units in bristol in the past, is a.) we used to run services there and b.) a fair few of out 150's are out on hire on fgw.
as for gen on 158820... pretty much impossible, it's what comes off shed on the day/what fills in for 175's tbh
Kneedown
29 Dec 2007
Nottinghamshire
From 04.00 Fri Morn until at least the same time Sat, 820 was residing in the shed on 11road at Crewe carriage sdg's.
