156s on far north line: timing vs 158s?
AHBD
9 Sep 2022
Northern Irelandm
It seems(75mph max) 156s were used on far north line, in the past, so I wondered how their timings to Thurso / Wick compared to the (90mlh max) 158s?
sprinterguy
4 Mar 2010
Macclesfield
3 hours 27 minutes was the fastest (and fairly typical) time between Inverness and Georgemas Junction with 156s in 1997, and around 4 hours 10 minutes for the full journey through to Wick via Thurso.
HighlandStorm
27 Sep 2024
Inverness
At the time of the 158s replacing 156s it was claimed the 158s were around 15 minutes faster to Thurso - but direct comparisons are difficult, in the 156 era, trains either split at Georgemas Junction or a change to a 156s that would shuttle to Wick was required. IIRC the Thurso first, then Wick, offering a Thurso to Wick and vice versa service begun with the 158s.
There was an attempt to speed up journey times by raising line speed at points where passenger comfort rather than safety set the speed, but this was reversed, and taking the 10:41 service northbound, the timetabled time is now around 18mins slower to Thurso than the fastest average time was in 2002. If trains don't keep time, the timetable can spectacularly fall apart very quickly, so if 156s or 153s were introduced to the mix, journey times would almost certainly have to be lengthened verse what the 158s currently do as there is more services overall on the line and Googling suggests the 158s have around 22% more power per tonne than the 156s.
Geeves
6 Jan 2009
Rochdale
The question you'd have to ask is how many sections of 90mph running are there north of Inverness?
It's unlikely there's going too much of a difference if it's all less than 75.
HighlandStorm
27 Sep 2024
Inverness
I found this in a 2024 FoFNL news letter: https://cdrltd.co.uk/fne/2024/FNE-91-D.pdf
The Far North Line is also severely compromised by lack of capacity for both freight and passenger
trains due to an inadequate number of passing loops. The highly regrettable 'temporary' slow down
of 25 minutes to passenger train journey times between Inverness and Wick, in force since 2005, was
due to the installation of a GB-wide safety system known as TPWS – Train Protection and Warning
System. Safety is all important, but might more have been done to adapt TPWS to our single track
lines?
The timetables have been further extended by a minute here and a minute there over the years. For
example, the 12:34 from Wick to Inverness now arrives at 17:08, 6 minutes later than in 2019. An
overall 4 hours 34 minutes. In 2012 that train took 4 hours 12 minutes and the connection at
Inverness enabled arrival in Glasgow 30 minutes sooner. In 2000 the same train was timetabled at 3
hours 48 minutes. That means that 46 minutes has been added to the journey time in the last 24
years, reducing the already slow average speed of 46 mph to a shocking 38.3 mph.
AHBD
9 Sep 2022
Northern Irelandm
I think I read sonewhere that the 156s were lower geared hence coukd accelerate from slow sections better: is that correct in any useful way forvthe FNL?
Railperf
30 Oct 2017
I've not seen a 156 that could accelerate faster than a 158 - unless the 158 had an engine out.
Rab Smith
7 Jul 2021
Cardiff
Talk of signalling the Southern end of the FNL with colour light signals and a new passing loop at Lentran would drastically improve timings between Dingwall and Inverness, by far the busiest section of the line. A passing loop at Kinbrace would also ease a particularly bad bottleneck between Helmsdale and Forsinard where currently there is a 30 minute section trip between passing loops.
Whether the money would be made available for this or not is purely speculative.
