sbrignall72
Does anyone please know the whereabouts of the above unit, as I haven't seen it yet this year, keep looking on RTT and not in service when I travel up there. MTIA
Ok thank youIt's on a C4 exam at Heaton, will be stopped for another few weeks at least.
How does a C4 exam take that long? Should be two or three weeks max.It's on a C4 exam at Heaton, will be stopped for another few weeks at least.
What does a C4 exam cover?How does a C4 exam take that long? Should be two or three weeks max.
thanks - I always get the meanings of the letters and numbers confused!C4 is the exterior of the train so bogies, couplers, under frame equipment and any other mods that might be required![]()
A C4 overhaul is anything underneath the train. Bogies, cardan shafts (which connect wheels to gearbox to engine), reservoirs, valves.thanks - I always get the meanings of the letters and numbers confused!
thank you! very helpfulA C4 overhaul is anything underneath the train. Bogies, cardan shafts (which connect wheels to gearbox to engine), reservoirs, valves.
A C5p is the paintwork, new livery or basic repaint into existing.
A C6 is the interior of the train, door systems overhaul, cab equipment (that's not covered as part of the C4 in some areas), seats, windows etc.
Those are bog standard exams on all fleets (except new build CAF/Stadler and so on).
C8, C10 are specifically Class 170 (and other variants, 165, 168 etc.) additional exams at different time periodicities.
156449 currently has a few extreme underframe corrosion issues so you won't see it until it goes to works at the end of this month (May).
Which works is it going to? WolvertonA C4 overhaul is anything underneath the train. Bogies, cardan shafts (which connect wheels to gearbox to engine), reservoirs, valves.
Should be.Which works is it going to? Wolverton
