James James
- Joined
- 29 Jan 2018
- Messages
- 432
Slovakia are apparently going to switch from 3kV to 25kV in 2023.Is there ever discussion of converting 1500 or 3000V DC lines to 25kV AC (or similar)? I appreciate this would be a big undertaking, but could it be worthwhile if done, for example, when electrical infrastructure was renewed?
Poland (currently 3kV) have talked about switching the whole network, but it sounds like that's not going to happen. However they have apparently decided on 25kV for the new build "CPK" (higher speed rail), and they might also be switching one highish speed line to 25 kV (the CMK has 250 km/h geometry, but is run at 200 km/h for power supply reasons, and they're trying to make 230 km/h possible which will likely involve a switch). Most polish loco's are 3kV, but they do have some newer multi-system locos and trains (Pendolinos) - and those are probably sufficient to service that line. (I'm pretty sure all the older locos that are only 3kV compatible also happen to only go up to 160 km/h, which stops them from using that line anyway).
