Quite a few of the WCML platforms were extended to cope with 11 car, main issues would be the termini at Euston, Picc, Lime St and Central. I think Euston and probably Picc have the length, Lime St and Central are tighter.
They wouldnt fit in a lot of stations for a start.
I have probably forgot more about actually railway operations than that 'expert' will ever know. Although he does know a lot about the financing and other stuff, the actual operational side of things he knows very little about.
If this was ever actually likely to happen... and remembering the source, I'm not convinced its anything but a pipe dream... but could they not use SDO (or something similar) on 12 carriage pendos at stations that lack a long enough platform?
Assuming that it wouldn't be the whole of the 390 fleet getting lengthened, could the longer units not be diagrammed for use on routes where there would be little or no issue...?
The problem is the terminus stations where the back of the train would foul the points/be over the track circuit, be wrong side of signal, the actual passenger side of things wouldnt be an issue.
I'm told that Chritian Wolmar has suggested that 12 car Pendolinos could be practical.
Opinions?
Would they fit in key platforms? [The 11cars seem to be pretty snug already in places!]
And what would be the impact on performance?
if certain key stations are viable to have 12 coach trains, would it not be better to replace the 2x5 Voyagers with 2x6 Mini Pedolinos
How much of the first and last coach is for passenger accommodation ?
Coach K has only 18 seats; don't forget the shop in coach C also takes up some room.
With the space lost to cabs and non-passenger areas, 2x6 would probably have less passenger space than 1x11.
There's another reason why 12-car Pendolinos are problematic. The original carriages are now around ten years old. If it was another two years before the twelfth carriages started to be delivered, there would be a big age discrepancy between the originals and the new arrivals. By 2044 the originals would be 40 years old and pretty well at the end of their lives; but coach no. 12 would be 11 or 12 years younger. Do you then scrap carriages which are under 30 years old?
An easier way to increase Pendolino capacity would be to convert 2 coaches from First to Standard Class.
Indeed, but I can't see Branny ever going for it. No doubt FirstGrope would have already done this, had their ICWC bid succeeded...
Wasnt First proposal to take one coach out of first class and introduce a club class (bigger seats than standard but ticket only includes a packed lunch rather than a cooked meal)?
