“Operational Incident”
HChip
14 Jul 2025
England
Hello,
I have seen just this afternoon that several Greater Anglia services are being delayed due to an “Operational Incident”. It is quite a broad term, what sort of things could this supposed incident be?
newtownmgr
2 Jan 2011
Fatality,Spad,Signalling failure,derailment or other safety of the line incident.
Would be a genuine incident not a ‘supposed’ incident as you seem to be insinuating.
Geeves
6 Jan 2009
Rochdale
I've added that reason myself for less serious things like rostering errors, missed station calls and train crew being late on duty. They all the affect the operation of the service after all!
saismee
20 Oct 2023
Looks to be a problem at Witham/Braintree.
Edit: Signalling failure.
ExRes
16 Dec 2012
Back in Sussex
Hello,
1300 1F45 cancelled and 1248 1F26 terminated at Witham, both due to signal failure (according to RTT)
TheWierdOne
30 Oct 2020
Does it also get used when nobody knows what the problem is yet? I.e: “Well something happened but damned if I know what it is”
1D54
1 Jun 2019
On a similar vein what does 'This service was cancelled at the request of the operator' mean?
I've seen it a couple of times this week on RTT with cancelled trains on the Stansted - Birmingham route.
A fatality is not an operational incident in phblic facing language. "Emergency services dealing with an incident" is the usual description for this now.
saismee
20 Oct 2023
At risk of derailing the thread further (though it is about delay/cancellation reasons, not a specific incident), I saw the delay reason of "This train has been delayed to maintain customer connections" for the first time recently. Certainly a positive!
321362
31 Oct 2023
If the set is needed more elsewhere that sometimes happens - iirc I've seen it when Southern 171s get taken from the Marshlink to work Uckfield services if there's a unit that failed.
GordonT
26 May 2018
In that eventuality the usual phraseology of choice is "due to a problem under investigation".
28 Feb 2009
Except I’ve seen LNER use it for en route delays incurred between stops, which stretches credibility a bit!
chrisjo
18 May 2024
Llanishen
Very frequently used by Freight Operating Companies who routinely activate paths 3 hours before departure time, and then more often than not decide they won't be running today. E.g.:
and
Lewisham2221
23 Jun 2005
Staffordshire
Hello,
SPAD, TPWS brake demand, AWS brake demand, wrong routing, station overrun/underrun, doors opened off platform, dispatch irregularities etc etc
Horizon22
Jobs & Careers
8 Sep 2019
Normally "operational incident" means "somebody has done something wrong / something has gone wrong / an error was made" outside of the normal operating rules / requirements.
This can include (non-exhuastive) a SPAD, SPAR, wrong-side door release, fail to call, wrong routing, signal irregularity (might be coded as "fault with signalling system" though) and other safety of the line incidents.
In passenger facing language, this normally comes up as "due to a problem under investigation" in Darwin.
Craig1122
14 May 2021
Linking with the thread about electric trains being wrongly routed...
SWR described one such instance at Wokingham as an "operational incident" on Twitter and were very coy with anyone asking what had actually happened. Even when a couple of people had replied to the thread with a photo taken from a nearby bridge of the class 458 attempting to break for freedom towards Guildford!
dk1
2 Oct 2009
East Anglia
The public are not usually given any further info as to what the ‘operational incidents’ are.
MrJeeves
28 Aug 2015
Burgess Hill
As I understand it, services can be pre-cancelled in TRUST so that the cancellation only gets reported at the time the service is called/activated (which happens automatically 3 hours prior to departure). It's not that the service gets activated and then the FOC decides to cancel it, but rather that the automatic calling of the service automatically sends out the cancellation message which has been added beforehand.
Retorus
30 Mar 2012
That’s clearly not what they were doing.
Unfortunately the terminology is often used without continuing the statement offering customers advice on what happens next for their journey.
Sort of becomes the opposite, 'not operating' and railway doesn't want to tell you why in customers eyes. So I get why it is often seen as a cover up.
dk1
2 Oct 2009
East Anglia
I suppose as an ex-railway employee I don’t question it although I must admit to being interested in what’s occurred.
Kite159
27 Jan 2014
West of Andover
Well technically it was an operational incident, the guard/dispatch staff not noticing the junction route indicator wasn't lit and the driver for accepting the wrong route
apinnard
2 Aug 2017
Kettering
Finally lol & yes thank you. Just waited for the two year dispute to be settled else i would've disappeared in 2023/4.
Nice one. Knew you were wanting to finally push the button a while back. More time for enjoying those ‘Spoons old chap!
