Why Isn't There a HUD for Train Drivers?
whhistle
30 Dec 2010
Coming from the thread about a train "doing 6x speed limit", I was thinking, why have we not impimented some sort of HUD (heads up display) in trains that can count down to important things like signals or TSRs, stations and junctions to assist drivers?
Thinking something similar to what I've seen on Train Simulator screenshots.
Maybe there is something already but I'd suggest the technology already exists so that's not it.
Ianno87
3 May 2015
That's essentially what a driver of a train using ETCS Level 2 sees.
Mag_seven
1 Sep 2014
here to eternity
Coming from the thread about a train "doing 6x speed limit", I was thinking, why have we not impimented some sort of HUD in trains that can count down to important things like signals or TSRs, stations and junctions to assist drivers?
Before we go any further, please tell us what a "HUD" is!
The_Train
2 Jun 2018
Keeps the rain off doesn't it? :E
I'll get my coat :( with its hood 8-)
Back to the actual subject, is this not what the Javelins on HS1 have?
baz962
8 Jun 2017
That's what it means , so I guess the poster was alluding to an electronic display in cab . Some systems have in cab signalling
AngusH
27 Oct 2012
To clarify the discussion a bit, a HUD or "head up display" is a display where the information is shown directly on the windscreen in front of the driver, hence "head up" instead of looking down at a display.
This is usually used in military aircraft as shown here:
https://en.wikipedia.org/wiki/Head-up_display#/media/File:Hud_on_the_cat.jpg
But also cars:
https://en.wikipedia.org/wiki/Head-up_display#/media/File:E60hud.JPG
RSSB (uk Rail Safety and Standards Board) did a report on this I think:
https://www.rssb.co.uk/library/research-development-and-innovation/research-brief-T513.pdf
See also this article:
https://www.railwaygazette.com/news/single-view/view/train-drivers-look-into-head-up-displays.html
Virgin trains did some simulator testing.
Hope this helps
edit: I'm not aware of any current usage of these type of systems, but would be very pleased to learn of them if they are happening!
Shaw S Hunter
21 Apr 2016
Over The Hill
But also cars:
Hope this helps
Interestingly both rail connected reports date back to 2007 with apparently no progress subsequently. I suspect that the financials involved don't stack up sufficiently well to make it viable.
AngusH
27 Oct 2012
Yes it is odd that there's been nothing since 2007.
I think there's also another longer project report of the same vintage behind RSSB SPARK that I don't have access to. :(
I think you're right on the costs thing. It probably wasn't seen as providing enough value.
I guess also if they added them then the display would be a safety critical -> "fail the train if it's not working" type of thing.
If it never gets added it can't break down?
Ken H
11 Nov 2018
N Yorks
Pity SRAWS (Signal repeating AWS) wasnt proceeded with
In the late 1960s, an enhanced form of AWS went on trial between Southampton and Bournemouth. Originally called "Southern Region AWS", its name was later changed to "Signal Repeating AWS". The SRAWS system repeated the next signal's aspect (and displayed a reminder of the previous signal's aspect) on an indication inside the cab. Any aspect other than green had to be acknowledged by the driver pressing the correct button that corresponded to the indication on display. If the driver did not acknowledge the indication, or the wrong button was pressed, an automatic brake application was initiated. The risk of error from subconscious cancellation was therefore greatly diminished.- http://www.railsigns.uk/info/aws1/aws1.html
AWS consists of a permanent magnet that starts the caution indication. This is suppressed by an electro magnet when the signal is clear. SRAWS dispensed with the electro magnet and instead had wires mounted in the 4 foot that transmitted the indication to the train.
whhistle
30 Dec 2010
This is where the rail industry gets left behind.
There seems to be nobody driving technology as quick as technology drives itself.
10 years later and I bet it'll be easier/cheaper to impliment but "the people" rely on a 10-year old report saying it's not viable :P
Shaw S Hunter
21 Apr 2016
Over The Hill
While I understand the point you are making it could also be the case that in this instance the technology, though potentially useful, is not worth the effort/cost required to install and maintain it. In the modern world there is sometimes a tendency to assume that every technological development needs to be adopted for use in every possible applicable situation. But that isn't completely true: whatever happened to video calls on our mobiles? Some applications prove to be narrow niches which may not be commercially viable. HUD could be fitted to every motor vehicle to allow drivers to confirm their speed without looking away from the road in front of them, and yet...
Indigo Soup
17 May 2018
SRAWS has struck me as really interesting since I found out about it. It isn't the full-dress continuous in-cab signalling system that many railways use - but would it have been sufficient to allow running at speeds above 125mph? Interestingly, I believe many continental European railways regard 100mph as the maximum speed without in-cab signalling.
bionic
8 Nov 2013
DAS is the railway equivalent of what you are talking about I think. It's part of the "digital railway".
mark-h
14 Jan 2015
Could this have been used as a protection system long before TPWS? The current AWS system only gives a green/not green indication to the train which so is not able to prevent (or emergency brake after) a SPAD. A multiple aspect system should be able to give more protection.
