The DJ
Lumo's northbound service leaves the ECML at Colton Junction and rejoins at Skelton Junction, an 11-12 minutes deviation. Is there any particular reason?
Its certainly not a 11-12 minute deviation.Lumo's northbound service leaves the ECML at Colton Junction and rejoins at Skelton Junction, an 11-12 minutes deviation. Is there any particular reason?
Yes, when the ECML was electrified and York was resignalled.were the centre roads at York removed during ECML electrification?
and gives enthusiasts the opportunity to do some rare lineIt avoids conflicts involved with running through the station.
(keep the enthusiasts happy and they may come back again and spend more money; ha, ha)If that were the case, all services would be routed via the avoiders. As it stands, only some services - all being northbound ones - are routed this way. It's a matter of pathing convenience; not going through any platform lines is a secondary benefit.One other reason for not routing via York is the risk of having one come to a stand in York station for pathing reasons creating a risk with passengers trying to board. Go round the back and risk can be reduced.
Some have clean paths through so can route through non-stop without issue or risk of coming to a stand. Any that have a lot of pathing risk coming to a stand.If that were the case, all services would be routed via the avoiders. As it stands, only some services - all being northbound ones - are routed this way. It's a matter of pathing convenience; not going through any platform lines is a secondary benefit.
Yes; no sense in up trains using the avoider as that would create more conflicts at each end of the avoider line.Three on a weekday, all Down direction.
Aha, I had been poking weekends (easiest day for me to have a trip out!) so that explains that. ThanksThree on a weekday, all Down direction.
Though, in terms of those available for the public, from the looks of it not until they ramp up their services in December?Two on SO and one on Sun.
Yes. I was going from memory looking earlier at the full plan.Though, in terms of those available for the public, from the looks of it not until they ramp up their services in December?
And, I suspect, vice-versa, that's to say that services "booked" via the avoiding lines won't necessarily use them I suspect.Might some of the down services that are planned to go through York station be diverted via the avoider if the station is congested with late running services?
Would take 6 months for that to happen so would be pretty unlucky to avoid (excuse the pun) it for that length of time.They will have to use them regularly otherwise Lumo drivers route knowledge via the avoiding lines will expire.
