Why do 175's not use hydrodynamic braking now?
Philip
27 May 2007
Manchester
I'm just wondering why isn't the dynamic brake on 175's used nowadays? Up until about 18 months back it was working, I could tell because they used to rev up loudly when braking, but I haven't heard it since. Considering they brake from high speed a lot it seems odd not using it and putting all the pressure on the disc brakes. I've not been on one for a while though, is it working again on some of them?
The 185s were also built with hydrodynamic brake and it was working the last time I went on one of those, although I've noticed Northern's 180s rely solely on very squeaky disc brakes too.
driver9000
13 Jan 2008
The Hydro-dynamic brake on the 180 was isolated some years ago when they were with Great Western after it proved very unreliable. I believe Hull Trains is the only 180 operator to use the HD brake.
No idea about the current status on 175s though.
7 Jan 2010
The 180's were isolated as they had problems with the braided hose that runs from the transmission to the heat exchanger bursting under the immense pressure under braking with the H-brake.
It seemed that they managed to mod the pipe but then they were having problems with the transmission oil temperature going through the roof under raking with the H-brake in which in turn made the coolant go over temp. which shut the engine down.
As far as i am aware Alstom had to foot the bill for the brake pads under warranty. Approx. £200 a pad which only lasted around 3 weeks as opposed to the 3 months or whatever they were meant to last with the H-brake in.
