Where will bi-mode locomotives (e.g. classes 99, 93, 88) be used?
class442
12 May 2024
Midlands
I know the idea of 99s on the sleeper has been much discussed and shot down, but I'm hearing that a number of 99s will be fitted with ETS and dellner couplers, and potentially used on the sleepers.
Northampton
Are you able to say from where/whom you are hearing this?
Class15
30 Dec 2021
North London or Mildmay line
Presumably the Class 92s could switch to working freight from Dollands Moor to Daventry, of which GBRf have af least one train a day. The remaining ‘92s’ could then be utilised on the car trains from Dagenham to Garston and Mossend. That could take up most of the ‘92’ fleet.
Clearly this is speculation but it could be a good way of making continued use of the ‘92s’, while the non-sleeper ‘99s’ could operate container trains out of London Gateway.
JohnMcL7
18 Apr 2018
What is the advantage of freeing up the 92s for freight work when the 99s could do that work?
How easily could these locos replace class 37s still in non-preservation use? Or could they displace 66s/68s that replace 37s?
43096
23 Nov 2015
You are proposing a “solution” to solve a problem that doesn’t exist. The 92s have settled down to give good reliability on the sleepers after the work GBRf put in to sort them out.
Class15
30 Dec 2021
I don’t want the 92s to be taken off the sleeper, but the post at the top of the page suggested that 99s might be fitted with ETS and Dellners for it.
Northampton
AIUI 92s aren't authorised to work north of Crewe due to the problems of their power draw (and possibly signalling interference?) EDIT: Corrected as per @Kite159's remark below!
This assumes anybody *wants* to make continued use of the 92s, which are now 30+ years old, don't have last mile capability and have always had problems with their power draw.
Class 37s are RA (Route Availability) 5, and 66s, 68s and 88s are RA7, so not very easily. Hence why 66s haven't already displaced them. Suggestion from early press articles is that 93s and 99s will also be RA7 but I can't actually access the articles to check the preview is correct.
Running RA7 locos on RA5/6 routes is possible but only with special permission, which usually involves quite a lot of low-speed restrictions over bridges.
Nottingham59
10 Dec 2019
For the 93 would that be because of higher axle loadings, rather than overall weight? The 93 weighs 86t compared to the 102t of a 37.
But maybe the higher maximum speed (110mph vs 90mph) makes a difference?
If that's the case, are there any new RA5 locos in the pipeline? The ones left are circa 60 years old and don't seem to have undergone a Class 47 to 57 or 56 to 69 overhaul that technically makes them younger than this.
43096
23 Nov 2015
So what are the Caledonian sleepers hauled by north of Crewe?
Northampton
Someone better tell GBRf that 92s are not meant to be used on sleeper services north of Crewe ;)
Fair point - I thought that might have been on special permission as there's less load on the system overnight but they're generally cleared in the Sectional Appendix for quite a wide range of routes north of Crewe.
I don't know, and I haven't seen anything official confirming the RA of a 93 or 99 at all. Other posts on another thread indicated one of them might be a different RA but that was equally as unconfirmed. RA isn't purely about axle load, it's also about the weight distribution and how it impacts structures.
None that I'm aware of (not that I'm comprehensively across stock news). However the need for one isn't particularly clear. Running a standard loco slowly for the handful of times you do need a loco-hauled train on a route that's RA6 or below is likely more cost effective than procuring a lightweight loco that would likely be a poor performer on a big bulk mainline 75mph freight flow. There's been trials of flows on low-RA routes (usually wood) and they've rarely if ever resulted in sustained flows. And if one did, there might be opportunities to eliminate the worst restrictions.
