When walking along track, why shouldn't you step on sleepers?
Magrar
20 Jun 2026
Reading
Just to be clear, as well as wearing safety boots, you guys who can't seem to do what my boots let me do, even carrying tools and boxes, you do actually know how to walk safely in potentially slippy conditions? Concentrating on placement, taking your time, etc. Because if not, well yes, you might as well be wearing crocs or even a pair of ordinary hiking boots, for all the good a decent pair of safety boots will do you on ice, oil or plant material.
Trough lids can move when stepped on and there is the potential risk of cracking them if regularly stepped on.
Ah, yes I imagine some of the ones from the 1960's might be a bit fragile by now !
Breaking of the lid is possible but it would probably be visibly damaged. I was thinking more of the risk of it becoming dislodged and dropping into the trough. I do remember being warned about that on a PTS course (30+ years since I did one but I doubt that has got any better).
I remember as a child looking from the train they always looked like little pathways !
Lockwood
4 Apr 2013
I've only had to walk track once. If memory serves, the extent of the briefing was to walk along this line or that line and NOT any further that that one, and to not stand on the rails. I don't think they mentioned sleepers at all.
We also hadn't been given any instruction on cess or 4 foot. I think we all trundled down the 4 foot to where we needed to be. I remember coming back that way and thinking "I need to move over soon, because there's point work ahead" and then doing quite a big step over the running rail and third rail.
I think I did have a bit of a slippery moment on one sleeper, but the ballast wasn't entire comfortable to walk on either.
I think all in all, it is an experience I am happy to have only needed to do once, and am not in a hurry to repeat
I would say that concentrating on stepping from one sleeper to the next has two risks.
First you are probably taking unnaturally large or small steps and some how this feels like it relies more on a good grip.
Second, while concentrating on looking down at where you are putting your foot leads to less effort looking and listening for approaching trains.
The same applies to walking in the fourfoot if stepping from one section of ballast to the next. If I recall correctly it's too short for a normal step but trying to step over two sleepers would be too far. This is one reason why the cess is safer, but only if a clear cess exists.
You need to be looking down when walking on the track. At one time patrollers would do this on live track, but these days it would be very unusual to be on a track when trains are running.
cats_five
19 Sep 2021
Do safety boots give better grip than walking shoes or boots?
When I was told to walk down the line that was the only instruction I got! It was about 40 years ago.
Peter Sarf
Croydon
Yes I think sleeper to sleeper is too short a step for my long legs but skipping two sleepers is too far. The cess makes more sense as does not interfere with ones walking rhythm except if there are too many obstructions there.
ABB125
23 Jul 2016
University of Birmingham
I imagine that some decent safety boots might give better grip than walking boots (and vice versa). But I don't think a generic statement could be made to that effect...
(Anecdote alert) I once did a weekend of walking in the Peak District in (really cheap) steel toes rather than walking boots because I picked up the wrong pair. I had no issues. Other experiences may vary.
Annetts key
13 Feb 2021
West is best
Wooden sleepers in particular, especially if they have a thin film of dew on them.
When I started working for BR Southern, I was given a number of safety leaflets. They included one about not walking on the sleepers, one about not stepping on the rails, and one about not stepping on the ballast (as the stones can move under your foot). So where was I supposed to walk? No leaflet about not walking on the live rail!
Yeah, I was told similar, don't walk on the rails, sleepers or ballast, and don't walk on the troughing. I so wanted to say, what, am I suppose to (insert appropriate coloured language) fly then...!
In the good old days of BR, along some lines, there were the remains of the cess path. This was a fine gravel rather than ballast sized stones (the old guys told me they were once so good you could ride the company supplied bicycles on them). And by far, was the best and easiest place to walk. The trouble was, it was rare for the railway to maintain them apart from along published walking routes (mostly along or near depots). They often got covered in spent ballast, earth from the sides of the cutting or old/new sleepers, rails and other items were left on them. Or some contractor would lay a new SCT route on top of the path because that was easier than digging a trench to put the SCT in (the lids of the SCT are or were supposed to be level with the surface of a path).
If the line was re-laid (or ballast "cleaned") using modern ballast machines that normally meant the path was toast.
Side note: during some works these days, there is a requirement to provide a cess path, so in some places they are making a comeback.
Where there was no cess path or it was overgrown, in practice, if the troughing route (officially surface concrete troughing - SCT) if actually concrete, in good condition and free of overgrowth was my preferred place to walk.
If having to walk along the four foot, and the sleepers were concrete with the tops clear of ballast and they were not slippery with moss or whatever, that's where I walked.
Otherwise I used to walk along on the ballast. If in the four foot trying to make sure I stepped on the ballast between sleepers and not on the ballast that was on top of sleepers. As loose ballast was just as deadly as a slippery sleeper.
The concrete cable conduit ?
Officially called SCT where I worked - see above.
High ballast shoulders were always my concern, particularly where you have a live rail at the top. Getting down in a hurry at least you can jump over the live rail and down into the cess. But climbing up a high ballast shoulder with a live rail at the top could be interesting.
Loose ballast lying on top of a sleeper can also lead to your foot slipping.
Old wooden sleepers with creosote or tar preservative often can have patches of the tar on them. While not dangerous, if the tar gets in the soles of your shoes, you could make yourself quite unpopular if you trod it in somewhere.
We used to get ear ache from the cleaner when we trampled dirt, oil or grease in...
As well as wooden sleepers being slippery or having excessive tar on them, the other problem was that as they rotted, many did so from the inside leaving them normal looking normal. Until you stepped on them, then the now very thin bit of good wood on the top would give way dropping your foot into the rotten core and maybe tripping you up in process... For some reason, these sleepers rotted more in the middle than the area under the chairs.
BR tried various designs and types of troughing. By far the worst for walking on was the grey plastic type. That was extremely slippery when wet or worse, when it was icey. More than once I've taken a tumble. And over the years, the plastic became brittle, so the lid would give way under your weight.
The concrete type, the short length (half a metre in length I think) design doesn't have metal reinforced steel rods. So if either the lid or the U-shaped base cracks...
The longer type (all one metre in length) does have metal reinforcing. So broken bases (U -shaped) is less common. However, the edges of the lids don't have metal reinforcing. So a part of the edge of a lid can either already be damaged or missing, but with the lid looking normal until you step in it, you don't know... Or very occasionally it can break when you step in it.
Trough lids can also, as well as the mentioned risk if them moving, be just as slippery as sleepers for the same reasons
Oh yes, especially if they spend a lot of time in the shade, like in cuttings.
Normal walking on them if the better concrete type does not cause damage. Most of the damage is done when the lids are not fitted correctly. Especially if whoever is doing it just drops them down instead of carefully lowering them. Or when they are tight, using brute force.
So that's what we were missing, we were all wearing Crocs so it's no wonder we were slipping and sliding all over. Safety boots are the answer, got it!
The railway supplied safety boots have varied in quality over the years, some bad good grip, others had very little...
And 30 years later some of those lids are now very brittle, we always taught to avoid walking on them. Obviously a lot of it is being renewed with polymer replacements that have a textured lid but in my experience they were still lethal in the winter.
The modern polymer type can cause you to build up a static electricity charge, which you get to know about when you then touch an earthed metal object (such as a metal fence)!
There have been various sleeper spacings used. Some of the older standards happen to be close to my natural stride. But the modern sleeper spacing for main lines are too close together for me. So I have to "quick step"...
Not always - see above. Also note that the safety boots required have to have a steel plate in the sole to protect your foot against shape things like nails... So the boot is less flexible.
Parham Wood
13 Jun 2011
In the 70s I did surveys which involved walking long distances along the track in West Wales, the Marches and some Welsh valleys. I preferred to walk in the cess where it existed and where is was still fine stone. However in many places the cess was either uncompacted ballast stones which were totally uneven and impossible to walk on or it had been taken over by the ballast shoulder so no cess at all. Walking in the four foot was the only option and it was rare that the ballast in the four foot was smooth enough to walk on, so sleepers it was with care. Yes you have to walk with shorter strides than normal. One technique was to step half on the ballast and half on the sleeper which stopped slipping. I would not liked to have walked in the four foot on third rail lines as getting out of the way of a train could involve stepping over the third rail rather promptly. Fortunately my only experiences of third rail was in South London where a good cess was maintained. I was never given any instruction about not stepping on sleepers, only about not stepping on rails or putting one's foot between the switch blades.
Rescars
25 May 2021
I'm pretty sure my safety boots could handle any of the scenarios here. The only places they even come close to being dicey, is seaweed or algea covered rocks. Which I don't imagine is applicable on the railway.
Not often of course, but once upon a time there was the Brighton and Rottingdean Seashore Electric Railway.....!
Lockwood
4 Apr 2013
Oh yeah, I think that was the other bit of my hasty briefing - stay away from the points. Which I had every intention of doing anyway!
Mikey C
11 Feb 2013
I was evacuated from a Southeastern 376 last winter, and had to walk for 10 minutes along the track.
I think we were told not to walk on the sleepers, though can't remember. I do remember that it was pretty uncomfortable walking along the ballast in thin soled shoes...
Perhaps the answer is to wait 10,000 years for human evolution to evolve feet like Alpine Ibex, then we can walk not only on sleepers without slipping, but up cutting/embankment walls as well ;)
Matangi
29 Apr 2023
New Zealand
Why are folks complaining about walking on the ballast? It's not something the average travelling public do very often. Awkward in Crocs or high heels maybe but not really an issue in boots. Safety boots do give another layer of protection by supporting your ankles in the event of a Torville and Dean moment. :D
alxndr
3 Apr 2015
Agreed, it’s easier than walking on a pebble beach in my opinion as the ballast locks together and doesn’t shift as much underfoot. Less comfortable in everyday footwear as you feel the edges more but not that arduous (I know this from areas of the depot that have been laid with spare ballast, not from wandering the track in trainers).
That said, I do notice when people are first out on track or when I’ve had to take emergency services lineside they seem to struggle, so perhaps it’s just something I’m accustomed to now.
cats_five
19 Sep 2021
Surely it's usually lots of bog-trotting in the Peak District? :)
I also did a trip to the Peak District in safety boots, and was fine until I got to a ford and found they filled up at much less water depth than proper hiking boots.
Annetts key
13 Feb 2021
West is best
One of my former team mates tested his new (new design/make to us at the time) safety boots at Chipping Sodbury tunnel when it was flooded. The water was about eight to ten cm (three to four inches) deep in the four foot and he declared his new boots were great as they kept his feet dry and warm.
9 Jun 2018
It's accepted that sleepers are slippery (and I'm not sure some realise quite how slippery they can be) and the railway has mitigation against this. Any railway worker who is on/near the line will have completed PTS where you are instructed never step in the sleepers.
If you do, and injure yourself or others, you could lose your PTS and possibly your job. It's a safety instruction you are required to carry out. Much like wear head or eye protection when required.
There's little need to stand on a sleeper during normal work, there's plenty of other areas to stand/walk.
ikari2006
11 Jan 2021
Bristol
Not sure if it's been mentioned, but in addition to the slips, trips falls, on the PTS course I did a while back, they said if in the four foot then you're further away from a position of safety if a train was coming. I recall on one site many years ago being told about further damaging the poor condition timber sleepers (colliery branch line). Walking on ballast is tiring and I've seen someone turn an ankle doing it so can see why people pick the sleepers or S&T troughs when an access route isn't present.
Lloyds siding
3 Feb 2020
Merseyside
I slipped on one only yesterday, where it was used to edge the lawn, and mark the boundary of my friend's property. Very slippery!
Trackman
28 Feb 2013
Lewisham
Stuff of nightmares.
There is a junction in SE land, which has a small cess of last resort with a gate and a metal ladder down to street level to escape. If you were trapped, there would be no way you'd be climbing up to the 4ft unless the live rail had been de-energised.
It got me thinking, it must have happened to someone at one time!
Lucan
21 Feb 2018
Wales
I regularly walked on them, and with experience I didn't need to look down because I adjusted my stride to the spacing. I would glance down regularly to check for obstructions and oiliness, and I would not walk in the four-foot near greasers and pointwork. If they were slippery I would have walked on the ballast instead, possibly treading half on the ballast and half on a sleeper. This was with a centre rail too - as I'm talking about LU open stretches. In LU tunnels it was dry anyway. I never had any slips but I'm probably a more agile and physically balanced person than most, with good peripheral vision. At the time I never received any instruction not to walk on them, although I was not a regular track worker. That was a while ago, probably different these days.
