What is this? Railway drainage?
bishopsrail
13 May 2026
Seaford
Hi. I'm interested is rail engineering and was wondering what this is?
There are a series of these grated covers next to or maybe above a culverted watercourse which runs parallel to the line. They all are on the rail land and have asset markers.
The track is on a hillside and the track itself is probably 10 metres above this point.
Apart from being at the angle, that blue grid is typical of a railway drainage ‘catch pit’, which allows them to suck out silt carried along the drainage channel, which will be a metre or so below.
There‘s a picture of a typical modern installation on a manufacturer’s website here, they typically use a concrete box made up of a number of levels:
Oh and welcome to rail forums by the way…
GRALISTAIR
11 Apr 2012
Preston Lancs
Thanks for your post. Definitely drainage. Welcome to the forum - your first post I see.
Sun Chariot
16 Mar 2009
Welcome @bishopsrail :)
To add to what others have already said here, photos linked below, show the drainage catch-pits installed for the rebuilt Bicester - Bletchley route.
6 May 2020
It does generally look like a catch pit at first glance. But it seems to have a plate that looks like a bridge number. That makes me think it might be an access chamber for a culvert.
Annetts key
13 Feb 2021
West is best
Some road over railway bridges have a culvert down the side of the railway cutting to divert water that may overflow where there is a stream or other drainage channel. This is done to prevent flood water from putting stress on the bridge parapet walls or causing the cutting from becoming unstable due to water from the stream or drainage channel from flowing uncontrollably through the soil.
At track level, they should direct water into the railway track side drainage system.
This is what the picture in the first post looks like to me.
