Web coding assistance please!
pdeaves
14 Sep 2014
Gateway to the South West
On my web site index page http://www.railwaycodes.org.uk/ is a collapsible list showing the corporate users, for which I have recently changed the coding. Previously when a user clicked the list the page jumped up to the top of the page at the same time. I have now solved that issue but inadvertently created another!
The font in the 'click line' is, I think, Arial, which is fine if your browser is set to that font by default. I cannot find a way to make this the same as everything else on the page (the user-specified default font). The hidden text picks up the page font fine.
Is there anyone who understands coding better than me who can suggest a way to 'unoverride' the font, please? Thanks!
GCRS
28 Nov 2016
Adding font-family: initial; to your button.accordion css seems to fix it, at least in Chrome.
pdeaves
14 Sep 2014
Thanks for the fast replies.
I have tried the suggestion but it doesn't seem to make a difference. Have I done it right? Any other thoughts?
pdeaves
14 Sep 2014
Thanks. I have tried the site from another computer and operating system and the font is consistent throughout (i.e. like I want it to be). It looks like my computer does not interpret the instruction as it should!
northwichcat
23 Jan 2009
Northwich
That usually means the code isn't quite correct but it's close enough for some browsers to display it correctly.
Equally, it could be that pdeaves is viewing a cached copy of the site. Certainly, I cannot see anything in the markup which would cause the font to display differently on that DIV only.
Out of curiosity, is there any reason you're using 1998's fonts? There are literally hundreds of fonts available for free with a couple of lines of CSS and if for some reason they aren't available the site will fall back to the default serif font.
northwichcat
23 Jan 2009
Northwich
I was presuming the advice above about clearing cache had already been followed.
At a quick glance the only thing I can spot is the use of the deprecated <font> tag but that's only been used to change the colour of the text.
I'm a bit confused about why they seem to have specified the font should be the browser default font.
