Very Light Rail (Potential Routes)
Halifaxlad
5 Apr 2018
The White Rose County
With this 'Very Light Rail' almost ready to be tested on its very own test track. I thought it may fun to speculate on potential routes where such very light rail vehicles could be used ?
For those who aren't familiar with this...
'Revolution Very Light Rail demonstrator vehicle prepared for testing' 24 November 2020
'First track laid for Very Light Rail' in Dudley' 23 November 2020
or its very own dedicated website: http://www.verylightrail.com/
Irascible
21 Apr 2020
Dyfneint
I can't see any performance figures in the places I can access ( I don't have a Railway Gazette subs ) - presumably you could use these on pretty much any secondary route if you built them with gangways? it's not like there's much freight around anymore...
Is what you've got there effectively the same thing as a Parry People Mover, but minus the quirky flywheel drive which was really a product of its time and not likely to come up again? I think it is?
If the rubber band snaps, I guess it'd be of use on the Stourbridge Shuttle.
For anywhere else, i.e. new build, wouldn't a low floor vehicle make more sense?
Irascible
21 Apr 2020
Dyfneint
There was mention of hybrid tech taken from road vehicles, so I'd assume more like a bus - the ultra light weight is presumably what makes it work. At least it's not four wheeled this time :)
The light build is presumably what would really restrict things.
Halifaxlad
5 Apr 2018
I think someone has developed a low floor version.
That's pretty much my opinion from what Ive read. Its basically going back to the 1950's railbus concept.
8H
6 Jul 2013
The substanative advantage of VLR be it low floor urban, or rural “rail bus” is the track itself surely, which is less obtrusive less limiting and less expensive making the civils cheaper and the geographical possibilities more interesting. The Units are the secondary issue here as the routes could be more innovative?
Irascible
21 Apr 2020
Dyfneint
Not sure of the power/weight of these things so I'm not sure you could be as careless of geography as a tram, for instance ( although in that case, build a tramway ) - but you'd expect to get away with lighter infrastructure yes. Not a PW specialist though, presumably there's minimum levels of ballast etc before the track starts moving around & so forth.
On the full network these things would surely have very cheap access charges.
Bayum
21 Mar 2008
I don’t like the name. Should change it to, ‘Really Very Light Rail’
