Valley lines stock
TheWalrus
6 Oct 2008
Hi
How many 150s does ATW use on its valley lines routes, including Ebbw vale but excluding Maesteg?
Thanks again,
Ryan
anthony263
19 Aug 2008
South Wales
there are normally 3 class 150's used on weekdays on the Cardiff - Ebbw Vale route at at least 4/5 on saturdays when trains are strengthened to 4 carriages.
there is normally at least 1/2 class 150's used on Penarth - Cardiff - Bargoed/Rhymney services.
TheWalrus
6 Oct 2008
Cheers
I was in Cardiff yesterday, it was brilliant, and Central is so busy!
merlodlliw
8 Mar 2009
Just arrived back from Wrexham, the Holyhead/Cardiff today ex WRX 0830
was reduced from a 3 coach 175 to a 2 coach 150. If you boarded at HHD
5 hours of pleasure, I don't think.
Standing room only. Not worth another thread for this, but ive also put it in
HDD/CDF thread for interest.
Then why put it in two threads ?? if a 175 has sat down for whatever reason then ATW will put whatever they have on the service. A 150 is better than a cancelled train, no ??
TheWalrus
6 Oct 2008
Which service off HHD?
merlodlliw
8 Mar 2009
agreed
which service off hhd?
0629 hhd/cdf
How many people actually use this service from Holyhead to Cardiff (compared to those using it between Holyhead and Chester and those using it between Hereford and Cardiff)?
From Holyhead to Cardiff, stats have been noted on the Premier service in 1st average 4 get on between HDD & Chester
in standard this train is used as a semi fast commuter & usually empties Chester & Crewe.
As for the D M Us, very few use the services, ex hhd to CDF after the 0629 when I have used the service.
The majority go to the North West from North Wales but politics in Wales ignores this fact.
