ThetrainguySE
Has the Set of points at elmers end ever been used?
Assuming they‘re operational they will almost certainly see occasional use for on track plant during possessions.Has the Set of points at elmers end ever been used?
Yes, used it a couple of weeks back. Trains can only leave the down platform ECS (empty coaching stock) in the up direction as there are no monitors at the London end of the down platform.Assuming they‘re operational they will almost certainly see occasional use for on track plant during possessions.
Have seen them in use from time to time when a late running Hayes service was turned back there, and formed the Back working to either Charing Cross or Cannon Street right time!Has the Set of points at elmers end ever been used?
And similarly the next day 2V13 0857 London Cannon Street to Hayes (Kent) terminated and formed 2K23 0954 Elmers End to London Cannon Street.On Friday just gone following an incident at London Bridge, 2V11 08:27 London Cannon Street to Hayes (Kent) arrived 38 minutes late at Elmers End at 09:30 and terminated, restarting from Clock House as 2K21, 12 minutes late at 09:38 returning to London Cannon Street.
It is definitely signalled for passenger use as seen above, there must have been some other reason on Friday.I guess the crossover isn't signalled for passenger use if trains have to go ECS to Clock House?
The crossover is fully signalled with a Main Aspect as opposed to a shunt signal.I guess the crossover isn't signalled for passenger use if trains have to go ECS to Clock House?
There’s no monitors at the London end of the platform, so a Driver cannot see themselves away as Southeastern don’t use “Lookback” as a dispatch method for Driver Only Operated trains.And similarly the next day 2V13 0857 London Cannon Street to Hayes (Kent) terminated and formed 2K23 0954 Elmers End to London Cannon Street.
