Unidentified GER station
lazonbytunnel
5 May 2023
Huddersfield
This faded photo has caused some head scratching on a Facebook group. Blake Hall was initially favoured but some commenters don’t think it ever had two platforms. North Weald was then suggested but some weren’t convinced by that suggestion either.
Gloster
4 Sep 2020
Up the creek
Some are saying North Weald didn’t have a second platform pre electrification
Well, it did have a lengthy siding, so could this have been the remnants of a removed loop. However, there wasn’t a platform shown on either the 1895 or 1915 25” maps.
If not, then you are probably looking for a line opened around the mid-1880s. That is presuming that there was a standard style for the era.
Unfortunately, Felsted doesn’t appear to have had a second platform. None of the other stations on the Braintree lines seem to fit.
John Webb
5 Jun 2010
St Albans
It looks like North Weald:
North Weald Station
© Copyright David Hillas and
licensed for reuse under this Creative Commons Licence.
And Alan Jackson's "London's local railways" (2nd Ed, Capital Transport, 1999) does say that the loop was added by BR in 1949, prior to electrification. The first Tube trains reached Ongar in 1957; the exact date the line was electrified and the oil lamps replaced isn't mentioned.
So perhaps it is North Weald just prior to electrification but after the loop and platform were installed?
eldomtom2
6 Oct 2018
Were North Weald's platforms shortened at any point? They look too long otherwise.
Gloster
4 Sep 2020
Up the creek
North Weald Station
Neither the half-hidden advert nor the style of lamp, or even the bit of awning visible, suggest late 1940s to me.
Royston Vasey
14 May 2008
Cambridge
Pampisford looks a possibility.
Station furniture certainly seems quite a close match on both sides.
https://www.cambridge-news.co.uk/ne...shire-railway-station-demolished-28407366.amp
Rescars
25 May 2021
That’s a good suggestion!
Even down to the slightly shorter right hand chimney pot. Unhelpfully, Blake Hall would appear to have had chimneys very similar to those in the OP. The second platform does narrow the search quite a bit.
stuving
26 Jan 2017
One feature matching the photo at Pampisford (and North Weald, but not Felstead) is the small outbuilding to the right of the main station building. It's about the same outline and orientation, though already half derelict in the photo.
And what about the canopy (or what looks like one) jutting into the picture on the left? Pamipsford did have one, though not I think at the start. But the picture I found shows dagger boards not in the photo.
So I guess that, given GER's habit of putting identical buildings at so many stations, we can never rule out it being "somewhere else not yet discovered in the record".
Royston Vasey
14 May 2008
Cambridge
It's hard to tell but I think I can make out the hint of dagger boards in the image!
David Burrows
1 Feb 2013
Definately not Blake Hall as was never other than single track and platform.
