Understanding RealTimeTrains data
pokemonsuper9
20 Dec 2022
Greater Manchester
SargeNpton
19 Nov 2018
The Unique Identity (UID) is allocated when trains are uploaded to Network Rail's Train Planning System.
It may only apply to a train on one day or it could be allocated to the same train for a complete timetable period. However, it is the only code that is unique on any one day. All other methods of identifying a train may be repeated on the same day in different parts of the country, or may be repeated on the same route at different times during the day where there may be an intensive service.
Yeah I still don't get why the additional ID was necessary
1V57 happens to be unique on the network today in that there aren't any other trains using that reporting number.
However take 2D06. Do you mean the 0430 Gravesend to Charing Cross? The 0628 Darlington to Saltburn? 0739 Leamington Spa to Stratford-upon-Avon? Or perhaps the 1845 London Liverpool Street to Cheshunt?
The UIDs are unique day by day so if you are looking at P55657 you know that that is the 0628 Darlington to Saltburn. There is no other train on the network today with that UID. This is important for planning and various other reasons. The reporting number is sufficient for signalling purposes as none of them are likely to show up to the same signaller at the same time. But the UIDs are important to ensure that you're dealing with the right service for other purposes.
Also, to be clear, this is nothing to do with RTT. These are internal industry identifiers that RTT is displaying.
SargeNpton
19 Nov 2018
Yeah I still don't get why the additional ID was necessary though. Both still have the same unique ID for a given day
Because it is the principal index in the current Train Planning System (and in the previous systems dating back 40 years or more).
Ahhh I see!!!
There was a thread way back where the questioner asked about duplicated train IDs (aka headcodes). Then as now, 2P12 was given as a good example.
So this is what RTT shows today, you'll quickly see it includes the Stourbridge shuttle which repeats 3 times:
hwl
5 Feb 2012
Ahhh I see!!!
Headcodes are effectively only unique within an NR region and within a ~6 hour buffer window.
Southeastern are the worst culprit for using headcodes twice in one day (same route and stopping pattern but ~1/2 day apart).
Northampton
There are several examples of headcodes in the same region within a 6 hour buffer - I'm fairly sure there's an avanti departure from Euston with the same headcode of rhe sleeper only a couple of hours ahead.
jnjkerbin
25 Apr 2012
Down south
Another common example are the 2Hxx Charing X - Tunbridge Wells trains and the 2Hxx London Bridge - Beckenham Jn trains, which often cause erroneous reports between London Bridge and Bricklayers Arms where both can be scheduled within an hour or two of each other, albeit on different sets of lines.
Boodiggy
8 Nov 2012
1M11
Horizon22
Jobs & Careers
8 Sep 2019
Used to be 6 hour, but I think the Elizabeth line has broken that now.
Often up to 4 trains a day with the same headcode, simply due to the sheer number of trains in sequence. Search any 9Wxx or 9Yxx headcode on a weekend and you’ll find a few.
Peter0124
20 Nov 2016
The ID changes on Saturdays and Sundays sometimes. Also the ID usually changes after new timetable change days.
norbitonflyer
24 Mar 2020
SW London
Are they completely unique for a given day though? Does an overnight train arriving at its destination on Tuesday morning have a different UID to the service starting out on Tuesday evening?
SteveHFC
1 Nov 2014
No - because the one arriving at its destination on Tuesday morning will have started on Monday evening.
Northampton
That would be the Monday train and Tuesday train. The fact it happens to run into Tuesday morning does not affect the UID rules. The departures are still 24 hours apart.
D6975
26 Nov 2009
Bristol
The Cumbrian Coast has lots of 2 a day headcodes, surprising as it's not that busy a route.
geoffk
4 Aug 2010
Exeter
Another example of reused headcodes - 2N99 at Northern - https://www.realtimetrains.co.uk/service/gb-nr:P45010/2023-08-11/detailed#allox_id=0 & https://www.realtimetrains.co.uk/service/gb-nr:P56393/2023-08-08/detailed#allox_id=0
Both however interact with Preston box, albeit the Blackburn train terminates at 1609 and the Blackpool train enters Preston control around 1800.
This must be very common with class 2 trains surely, but less so with class 1. What about freights?
Tom
19 Jan 2008
35,000ft
The uniqueness is defined as the combination of service UID and departure date from planned origin.
e.g. if a train on Monday actually started short and departed en-route from its first station on a Tuesday, and the Tuesday version ran to plan, the altered Monday train is still unique as it was planned to depart on Monday
Not entirely uncommon.
15 Apr 2020
Wakefield
Not uncommon for class 1 or freights to not be ‘unique’ on a day at all.
Most examples on this thread have been of the same headcode on the same panel, but it’s just as important for systems to differentiate between them across the country - for example a quick search on RTT shows there are 5 1A04s today, each of course needing their own UID.
jfollows
26 Feb 2011
Wilmslow
Going back in time, headcodes were sometimes used as route indicators, for example 2H54 was used for Alderley Edge-Altrincham via Stockport and 2H53 for Alderley Edge-Altrincham via Styal, in both directions. So two trains with the same headcode often passed each other. This from 1974, still the case in 1977, but at some point it was changed. It couldn't happen today for obvious reasons but also because Alderley Edge is now deemed to be in the Stoke-on-Trent division like Crewe and so trains terminating there are now 2Kxx rather than 2Hxx.
_toommm_
8 Jul 2017
South West London
Forgetting the xQxx and xZxx headcodes as they’re for special circumstances, there’s 2,400 unique headcodes for each class of train per day, 0 through 9. I’m sure in the 1Xxx and 2Xxx series, there’s probably ones unused, put also as noted above lots of duplicates.
Vexed
12 Jan 2020
Herts / Hants
There's some very close ones at Farringdon between the Elizabeth line and Thameslink such as the first 9T43 departing at 1527 then Thameslink's 9T43 departing less than half an hour later at 1554.
Today there's also an early morning TL 9T43 which is 9W13 in the WTT but is a 9T today because it's running via London Bridge instead of Elephant & Castle/Streatham Common.
Horizon22
Jobs & Careers
8 Sep 2019
Although it’s the ‘same’ station, they are different infrastructure routes of course.
Class15
30 Dec 2021
North London or Mildmay line
It’s a little confusing as the headcode system on the NLL means that there is generally one 2Nxx going one way per day and another 2Nxx going the other!
