TVM mixed with conventional signals in custom route
trc666
6 Jul 2005
Islington
Currently working on a test track route for TS2013 which is going to have a section of TVM signalling on one of the lines, but having a few problems with it.
When entering the TVM section the train picks up the speed limits no problem but upon leaving the TVM section the second to last block post gives a speed of 000 and the final one causes a penalty brake application despite the first 'conventional' signal being green. I'm using standard block posts and an AWS commence sign to exit the TVM section which seems to be the same way that it's done on the Kent High Speed route on the approach to St. Pancras International - any idea where I'm going wrong?
