Trivia : Furthest station from London/Highest Frequency Combo
GordonT
26 May 2018
Which station is the furthest away from its London terminal or terminals with the highest number of trains per hour in a typical hour to/from London? I've probably not phrased that as well as I should have. What I'm meaning is the furthest distant station from London with the highest frequency to/from London if that explains it better.
Peter0124
20 Nov 2016
Probably doesn't answer your question properly but I just had to mention this.
Between 10:50 and 11:31 on Sundays, Edinburgh has FIVE trains to London with one being Avanti, one being Lumo and the other three LNER.
The Avanti is not currently running weekends due to Carstairs being blocked but is back in June.
Mcr Warrior
8 Jan 2009
Birmingham New Street is somewhat closer than Edinburgh Waverley, but has 4 TPH to/from London, during most of the day, each and every hour and not just for any one (un)typical hour on a Sunday morning.
duncanp
16 Aug 2012
Two of which are stopping trains via Northampton, which get overtaken by later Avanti services.
Manchester Piccadilly, with three fast trains per hour to Euston, must be one of the contenders for this thread.
Mcr Warrior
8 Jan 2009
Don't think the divergent route South of Rugby automatically excludes the "slow" services to/from New Street, as per the OP's stated criteria. In any event, isn't one of the regular 3TPH Manchester->London services routed via Crewe, the other two via Stoke-on-Trent?
Horizon22
Jobs & Careers
8 Sep 2019
An odd question because on this criteria is 2tph 300 miles from London or 4tph 150 miles away, better, equal or worse?
Magdalia
1 Jan 2022
The Fens
No, you haven't explained this.
Generally speaking, as distance from London increases, frequency decreases. It is a trade off.
For example:
place A is 50 miles from London and has 4 trains per hour
place B is 100 miles from London and has 2 trains per hour
What criterion do you use to decide which of those is "higher"?
To have a "highest" when varying both distance and frequency you need to define a variable V that is some function of distance from London D and frequency of service F.
For sake of argument, that could be V=D*F. On that definition places A and B above are equal at V=200.
GordonT
26 May 2018
Would it be a more meaningful question if I prefixed it with the words "Within a 100 mile radius of London"?
PGAT
13 Apr 2022
Selhurst
100 miles measured as the crow flies or by the route of the track?
Magdalia
1 Jan 2022
The Fens
No.
For example "within a 100 mile radius of London" includes both Clapham Junction and Leicester. Is that meaningful?
What would be meaningful would be to ask what is the station that is furthest from London that has at least a specified number of trains per hour.
But you then have to say which trains count and which do not. For example are you including slow trains that are overtaken by fast trains? Are you including multiple termini? Are you including trains that run through London and out the other side, such as Thameslink?
GordonT
26 May 2018
No.
I was meaning the furthest station from London terminals but not exceeding 100 miles. Not every station within 100 miles.
In the case of Thameslink, good point, take the mileage from City Thameslink.
Dr Hoo
10 Nov 2015
Hope Valley
So, Leicester is 99 miles from St Pancras International and has four trains in a typical hour on weekdays.
alistairlees
29 Dec 2016
To get to an "answer" you could multiply the number of services by the distance in miles. However miles are measured (straight line, track, to one London station only etc.) I would have thought the answer will be Edinburgh (33 services today over 393 miles = 12,969). Reading also does pretty well, at 36 miles * 260 services = 9,360 (this will actually be slightly higher as 35 services go to Waterloo). Clapham Junction has over 900 services, but is less than 3 miles away.
Northampton
But this answer could be utterly meaningless to the OP, who could just as easily be asking for generalised journey times to London.
PGAT
13 Apr 2022
Selhurst
But the question is directly asking about frequency, not journey times.
Northampton
The OP was asking for a function of Frequency (a form of time) and Distance. Generalised Journey Time would be as potentially useful as anyhting suggested in the post I quoted.
GordonT
26 May 2018
My interest would probably be better served by asking which of the London daily commuting outliers of the likes of Cambridge, Peterborough, Leicester, Milton Keynes, Oxford, Reading, Brighton has the best frequency to/from London and is there anywhere further from London, with a rail connection to/from London with the same or better frequency.
AM9
13 May 2014
St Albans
So are you scoring each occurrence, e.g. number of train miles per hour?
That would bring a whole lot of shorter but busier routes, e.g. Bristol Parkway, Brighton, even Reading!
Northampton
Brighton (50 miles) has 4tph Thameslink direct to London Bridge, if you change at East Croydon you also then have large number of Victoria services.
MK (50 miles) has 1tph stopping, 2tph Buzzard semifasts, 1tph Crewe fast, and (used to?) Have 3tph Avanti fast. So 6tph that will do the journey without being overtaken.
AM9
13 May 2014
St Albans
So is it focused on the London Terminal of the Country destination? For example Brighton would have Victoria and Thameslink sources, whereas Reading would be Paddington and Waterloo.
GordonT
26 May 2018
To/from any London terminal or City Thameslink without change of train in either case.
sk688
11 Sep 2016
Dublin
Swindon has the Cheltenham service , the 2 Bristol via Baths and the 2 South Wales services per hour into London IIRC
