Train destroyed by fire in Berlin
AndrewE
9 Nov 2015
That is astonishing... I thought that after our Taunton sleeper fire (and one in an ex-LMS EMU at West Kirby or somewhere like that) the flammability of train interior materials was strictly limited?
The exile
31 Mar 2010
Somerset
Niederbarnimer Eisenbahn 643.14 apparently. Suspicions of arson.
AndrewE
9 Nov 2015
but even an incendiary device with extra accelerant shouldn't be able to turn a train into a raging inferno like that...
The exile
31 Mar 2010
Somerset
Maybe another answer to “why is everything so expensive in this country?”!
AndrewE
9 Nov 2015
I suspect a train completely written off (and the damage to the OLE) is probably going to be a lot more expensive than making it from materials less vulnerable to fire in the first place... Good job it didn't happen in a tunnel
dosxuk
2 Jan 2011
Even fire resistant materials will burn when exposed to a sustained flame for long enough. The idea of using them is more about giving people enough time to escape before it turns into an inferno, rather than preventing it from burning at all.
The restrictions on materials used in aircraft are even more stringent, and yet...
The exile
31 Mar 2010
Somerset
No OLE at Ahrensburg (IIRC) and the replacement stock is currently awaiting certification, so in this case possibly not.
duesselmartin
18 Jan 2014
Duisburg, Germany
I do believe fire safety (when it comes to non-flamable material) in the UK are the strictest in Europe if not beyond.
merry
19 Oct 2011
Materials standards in modern build trains are governed by EN45545:2021 ( and older versions back to 1990s) which puts some strict controls on flammability of all materials (strictest for underground use especially with limited means of escape, and sleepers, than for above ground use only). But older stock will not be as resistant, and some Berlin S bahn stock did look a bit dated on my visit this year...i assumed it was older.
And as noted by others, the intent is to allow safe escape, not stop fire altogether.
The only way to (almost) totally avoid fire is only have bare metal finishes on everything, even seats, no paint, plastics or padding or anything else soft inside. Even then light fittings, wiring, electronics, suspension, seals, lubricant etc have to use some slightly flammable (insulating) items. So all useable trains will burn if you really try...
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Part of problem with aircraft is the fuselage will burn, not usually an issue with trains although there are some made of lots of GRP or similar.
