The Retro Welsh Dragon 2 - Saturday 15th July 2017
Crossover
4 Jun 2009
Techniquest
19 Jun 2005
Nowhere Heath
Oh now this is interesting, it's due to pass Hereford 5 minutes before my last bus home that evening. I might have to try and see it...
AnthonyRail
11 Jan 2015
Booked part fare return £20 thanks for posting. Wasn't aware of it and need 37 mainline haulage.
Any other forum members booked on this?
The mini tour is still open for bookings. £15 single (either direction) or £20 return. The mini tour consists of:
  • Cardiff (depart 1136) to Swansea (arrive 1227) via the mainline
  • Swansea (depart 1520) to Cardiff (arrive 1659) via Rhoose and Barry
Crossover
4 Jun 2009
We shall endevour to give you a wave as we pass if you're there :)
You're welcome - hopefully we can say hi at some point in the tour :)
Crossover
4 Jun 2009
Unfortunately slightly late running is the order of the day - every gradient sees us struggling a bit
Crossover
4 Jun 2009
The word on the ground was 37606 (behind 37602) developed a fault on the outbound and wouldn't take power - this was evidenced as the ECS left Huddersfield with no real noise from 606 other than idling.
Really not bad going to say that a single 37 doing all the work was more or less keeping time singlehandedly with a large rake of coaches and the weight of two 'dead' locos (37606 and 57306 which was providing ETH from the back)
Techniquest
19 Jun 2005
Nowhere Heath
I have to confess to completely forgetting you guys were coming through my way, I was in Yates enjoying some Butty Bach!
A single 37 having all that work to do must have put a lot of pressure on the engine, I must confess to not seeing why they didn't just rip out the 37 that wasn't working before departure, waste of time taking it with you!
It was working on departure and failed after Shrewsbury and they were hardly likely to leave it at Swansea!
Crossover
4 Jun 2009
I've since heard that 602 failed at Heaton Norris on the return ECS with a wheelset fault
Techniquest
19 Jun 2005
Nowhere Heath
Ah fair enough, I misread Crossover's post which I thought had said it wasn't working before departure from Huddersfield :oops:
Should have dumped it in Hereford and given me something different to look at :lol:
My informed source suggests a small traction motor fire occurred but apparently there is a good phot opportunity if anyone wants of the disgraced duo.
Starmill
18 May 2012
Bolton
I think we should all consider ourselves lucky they didn't use the 57 instead. It may have been justified to give us the extra power :p
Crossover
4 Jun 2009
I wouldn't be surprised with all the work it was forced to do!
It forced me to spend 20 minutes longer in Reddish than I was supposed to. Do you think I've got a leg to stand on for a complaint?
It forced us to spend 20 minutes staring at trees (and Traksy!) at Denton Junction - we all have a cross to bear :P
Had it been up to some, we'd have gone with no train power to have rid of the 57 :P
