TFW Timetable December
Phil from Mon
28 Nov 2014
Beaumaris, Ynys Môn
From the TFW stock shortages thread in rolling stock
Tfw have released a new blog yesterday outlining some rolling stock plans
https://tfwrail.wales/one-year
“One of our key commitments was to speed up journey times between north and south Wales. From December this will be in place, shaving off more than 40 minutes on the current journey time.“
I’d not seen that before. Anyone know if it is all trains or just a selected few? Quite a step change in any case. Also confirms the substantial increases in Sunday services mentioned elsewhere.
Edit: Just looked in RTT and can’t see any sign of an acceleration there yet.
Imagine it's the extra loco hauled workings? Think this is the fastest
https://www.realtimetrains.co.uk/train/Y90765/2019-12-17/detailed.
But the blog is misleading if you don't remember the original proposal.
anthony263
19 Aug 2008
South Wales
Many off the off peak swanline services have been retained to leave Swansea earlier at p5 minutes past rather than 10 past the hour. By the looks of the timetable the swanline services are only 3 minutes or so in front of the swansea to london services by the time they get to Cardiff central. Extending some of the ebbw vale to Cardiff services through to bridgend would prove popular especially if the previous gwr services are very busy.
anthony263
19 Aug 2008
South Wales
Here is one timetable I've found online for tfw local services between Cardiff and Swansea
  • Table 169.pdf
Jez
22 Jan 2011
Neath
I have noticed they have swapped the first Swansea-Manchester and it now departs Swansea earlier and forms the Swanline service and goes to Manchester whilst the 0707 now goes as far as Cardiff.
DaveHarries
12 Dec 2011
England
Indeed it could do but I think it would be more likely to be the other way around. I remember once standing on Platform 2 at Cardiff Central waiting for the train to Bristol Temple Meads. Looking across the line I could see that Platform 3 was heaving. An ATW (as it was then) Class 17x turned up and took as many passengers as it could but Platform 3 was still packed when the 17x left. The next train on Platform 3 was a 10-car Class 800 to Swansea and when that had left Platform 3 was empty.
Dave
Jez
22 Jan 2011
Neath
The arrival time of the Swanline in Cardiff Central will have some padding in the timetable as the service terminates there. At Bridgend it is about 8 or 9 minutes ahead of GWR and there are no stops between Bridgend and Cardiff so should arrive in Cardiff earlier than the advertised time. Having said that it is still a performance risk to the GWR due to often losing time with the regular stops between Swansea-Port Talbot especially if it is a 153.
I noticed that one of the West Wales to Manchesters (think the 1055 from Swansea) from December timetable terminates at Cardiff and requires a change to continue journey onwards to Newport and Manchester. I wonder why this is. Assume they are just using a different set from Cardiff.
Belperpete
17 Aug 2018
I note that there are many train cancellations on the Cambrian network this Sunday due to shortages of train-crew. How realistic is the significantly improved Sunday service from December if they can't even resource the current meagre service?
Tomos y Tanc
1 Jul 2019
TfW did employ a large number of trainee drivers (around 100 IIRC) shortly after taking over the franchise. Presumably they'll be compleating their training around the time of the timtable change.
craigybagel
25 Oct 2012
Some of them are already qualified and are out and about productive. Lots more to come and both training schools are very busy - as soon as one group leaves another one moves in.
Envoy
29 Aug 2014
It is regrettable that passengers from Barry/ Rhoose & Llantwit Major have a wait of around 20 minutes at Bridgend before they can progress westward - usually on a GWR train.
Why does it say "Grangetown (Vale of Glam)" on the timetable? Grangetown is not in the Vale of Glamorgan but in Cardiff.
Tomos y Tanc
1 Jul 2019
Maybe it's a reference to the line in order to differentiate it from the Cityline's Ninian Park which is also in Grangetown. You'd have thought the stations having different names would have been enough!
Envoy
29 Aug 2014
I thought that Ninian Park was in Canton. (it is right by the Canton depot).
Phil from Mon
28 Nov 2014
Beaumaris, Ynys Môn
Further to their “key commitment” to reduce times between North and South Wales, just had confirmation from their Twitter people that the only acceleration is the 0702 departure from Cardiff. Disappointing for them to spin this the way they have as a general improvement.
Wilts Wanderer
21 Nov 2016
In the until the early 1990s there was another Grangetown station near Middlesbrough, this might be why Grangetown (Vale of Glam) is so designated.
https://en.m.wikipedia.org/wiki/Grangetown_railway_station_(England)
krus_aragon
10 Jun 2009
North Wales
Tomos y Tanc
1 Jul 2019
The station is in the Grangetown ward. Canton is a pretty amorphous concept. Strictly speaking, the Canton depot is in Riverside and Grangetown wards.
33017
9 Sep 2017
Technically, I believe the entire depot is in Grangetown (Brickyard Sidings and the SWCC are in Riverside), although the entrances to both Ninian Park station and the depot are both off Leckwith Road, which is in Canton.
Rhydgaled
25 Nov 2010
PDF timetables now online. I had a quick look at timetable 3 to see if there were any improvements for Fishguard but was disapointed. They haven't even got rid of the now-pointless overnight train, although there is an error with the eastbound version of it on the Monday-Friday timetable. It is shown as a GWR service running through to Paddington! (see attached screenshot of that page of the timetable). Must be an error though as the inbound working is shown as a TfW service.
PHILIPE
14 Nov 2011
Caerphilly
Obviously TOC error. TFW cannot get rid of the pointless train because it was in the Franchise spec based on the previous Stena sailing which, I presume, means a train must run between this and that time.
Rhydgaled
25 Nov 2010
That was the case with the ATW franchise agreement (although didn't they withdraw it for a while before realising they had broken the franchise spec?) but I assumed that the new franchise spec would have fixed the flaw in the old one. Must confess that I can't currently remember the terms of the TfW contract.
24 Jul 2011
Wigan
Well spotted!
It looks like they may have accidentally merged two services - the 02:37 from Fishguard to Carmarthen and the 04:58 from Cardiff to London. Certainly wouldn't expect to see first class and a trolley service on a train from Fishguard to Carmarthen at that time :D
Baxenden Bank
23 Oct 2013
So, why not change the franchise spec? Will there be large numbers of individuals or stakeholders objecting to the loss of a very unsocially timed train?
Seems rather wasteful to run this train simply because it's easier than agreeing a change. Far better to phrase the specification to 'two trains per day must operate to connect into, and out of, ferry sailings from Fishguard' - with perhaps a minimum/maximum connection time specified. That ensures a proper service for those who may wish to make a rail/sea trip.
Do the current other Fishguard trains make a good connection into/out of the ferry?
Rhydgaled
25 Nov 2010
There are two sailings each way per day:
  • the 12:28 train arrival appears reasonable for the 13:10 to Rosslare
  • the 22:46 train arrival appears reasonable for the 23:45 to Rosslare
  • the 11:15 arrival from Rosslare is met by the 12:40 train departure
  • the 21:25 arrival from Rosslare is met by the 23:03 train departure
As well as the basicly pointless overnight working, there are a few more trains to/from Fishguard (14:xx on Sundays and four (06:xx, 07:xx, 09:xx and 19:xx) Mon-Sat) that don't have ferries to connect with. The 20:xx to/from Fishguard (which connected out of the 17:39 Cardiff-Milford service) that was introduced in 2011 was replaced by the 22:46 Fishguard arrival when the ferry was retimed.
The ATW specification did indeed require connections with the ferries (as does the new TfW specification) but made the mistake of also specifying that a train should run overnight. I'm not quite as clear about whether the new spec requires the overnight train, as it is presented in a different way.
Baxenden Bank
23 Oct 2013
Connections from the Pembroke branch into the Cardiff/London trains at Swansea essentially eliminated.
Printed/pdf timetables riddled with pretty basic errors.
There is no 1709 from Pembroke on Fridays!
There is no connection from the 1919 Pembroke to Tenby. Meanwhile a train arrives at Tenby from Carmarthen with no onward working to Pembroke Dock. No sorry, they are there, just 7 and 14 columns later respectively!
