Speculation: Could GWR run to Fishguard Harbour again?.
james60059
6 Jul 2006
Hinckley
Since the introduction of the IET's, could it be feasible for GWR to operate the boat train again to Fishguard Harbour?. Especially since Stena Line altered their ferry sailing times last year could a direct London > Fishguard service attract more custom?.
One idea could be a double set of 5 coaches to operate as far as either Swansea or Carmarthen, where one set could carry on to Fishguard Harbour calling at Llanelli, Whitland, F&G and Fishguard Harbour.
Spittal Tunnel on the Fishguard branch shouldn't be an issue as that's a double track bore.
Cheers
James
cactustwirly
10 Apr 2013
Cheers
James
Yes it's possible, I don't see why they would?
The Fishguard route is on the decline, there are very few foot passengers, not least from London.
It's a much better use of resources if a good connection was offered from Swansea to London, with ATW operating a shuttle to Fishguard
_toommm_
8 Jul 2017
South West London
They could definitely, it's just the question of whether you'd have passengers using it. They may use it for the flows in which GWR already operate, but I doubt the Fishguard portion would be worth it. Operating to Swansea more regularly, definitely as lots of connecting ATW trains are available there. It's just a too tiny section to justify the training and route knowledge retention.
Mag_seven
1 Sep 2014
here to eternity
Network Rail would need to gauge clear the Class 800's west of Carmarthen first - something which they are not currently remitted to do.
Envoy
29 Aug 2014
Most people would surely like to see a speed up of services west of Cardiff. This could possibly be achieved by using the Swansea District Line - with a new station by the M4 at Morriston (north Swansea). I understand that the speed limit on the SDL is 60mph but that it has decent tracks and therefore fail to understand why higher speeds are not allowed. I well remember as a teenager catching the Fishguard to London express. When it left Llanelli, it headed up the SWL (now part of the Heart of Wales route) towards Pontarddulais before proceeeding east to reconnect with the mainline at Briton Ferry near Port Talbot. Anyway, it went non stop from Llanelli to Cardiff. The same route is used today by ATW for some Fishguard trains. (Train 1B97 which leaves Llanelli at 14.10 and reaches Cardiff in 1 hour 8 minutes - with 1 stop at Port Talbot).
Regarding west of Carmarthen: the problem is that we have three branches = Tenby & Pembroke Dock; Milford Haven; Fishguard. The first two only have one train every other hour and the Welsh Government have not requested that this be increased by the new company who will take over from ATW. I think that this is regrettable. So, it would surely be ideal to increase the frequencies on these branches and that would require short trains - certainly running west of Carmarthen. Such trains could also be used as stoppers going into Swansea - as they do at present.
Rhydgaled
25 Nov 2010
Probably because so few passenger trains use it (there are only about 3 trains per day total between Carmarthen and Cardiff that don't call at Swansea and some of those run via the single track behind Landore depot rather than using the SDL). The freight trains, sometimes hauled by class 60s, don't particularly need high linespeeds so I guess Network Rail are only maintaining the track to 60mph standards; cheaper than maintaining it for higher speeds. There may also be some limits due to sighting of user worked crossings etc. Unfortunately, as well as the new Wales & Borders franchisee apparently not being interested in South West Wales, the GWML west of Cardiff is only double track. With the stopping trains to Maesteg (possibly going up to 2tph), Swanline services (hopefully going up to full hourly) and freight, we fitting extra fast services in could be difficult. In my view there needs to be either a new, shorter, route between Cardiff and Bridgend for fast services or there needs to be four-tracking of all or part of the current GWML between Cardiff and Bridgend. If this is only a partial 4-tracking, then it must include at least one station (perhaps the new one at Miskin) to allow fast trains to overtake while the stoppers call. If a path can be found; I would like the new franchise to drop its commitment for 100% fleet replacement in order to retain either the 158s or the 175s (which is tricky as there are pros and cons to both options) for Cardiff-Carmarthen-Milford/Fishguard fasts, with the units also being used on HOWL services and perhaps the Conwy Valley.
I agree; I think there should be 3tph to Carmarthen (1tph express Cardiff, Port Talbot, Llanelli only and 2tph Swansea-Carmarthen (1tph all stops, the other ommiting Kidwelly and Ferryside)). The Milford Haven line defininately needs to go up to 1tph; not 100% clockface though as it should be a mix of Swansea and Cardiff trains, as should the Fishguard line (to AND from Cardiff for both boat trains, Swansea the rest of the time). Fishguard should have a mix of 2hr and 3hr gaps between trains (basically have the 07:50, 09:50, 18:50 and 20:50 services with a maximum of 3hr gaps the rest of the time).
Unfortunately even a train every half hour Swansea-Carmarthen with most trains continuing west is not possible without more double track (or passing loops) west of Carmarthen. The loop at Tenby is in the wrong place compared to the Fishguard and Milford lines; if a train leaves Whitland for Pembroke Dock half an hour after one to Fishguard or Milford the two trains would get back to Whitland within a few minutes of each other. To allow for a regular half-hourly service between Swansea and Carmarthen there needs to be a dynamic loop somewhere between Whitland and Tenby (probably just north of Kilgetty but I may be remembering incorrectly), and that still only gets you a train every two hours on the Pembroke & Tenby branch (you might be able to go hourly to Tenby, but would have to waste stock sitting in Tenby for hours or replace Tenby - Pembroke Dock with a bus). Hourly to Pembroke Dock I think requires two additional passing loops (the aforementioned one and one west of Tenby).
Also this is perhaps off topic since short DMUs (156s might have been nice, for the Swansea trains) are appropriate for Pembrokeshire services, not expensive 125mph GWR bi-modes. Perhaps if any of GWR's London-Cardiff trains are booked for 5-car sets they could be extended to Carmarthen via the SDL (a 9-car won't fit in Carmarthen apparently).
83G/84D
28 Oct 2011
Cornwall
According to the latest IET clearances they are cleared between Carmarthen Jn and Whitland but not between Whitland and Clarbeston Rd. Not allowed into Whitland Bay platform and restricted at Tenby.
They are passed to Pembroke Dock with some restrictions.
Not allowed between Clarbeston Rd and Haverfordwest.
Noted platform validation comments in other thread.
4-SUB 4732
7 Jan 2018
The 07:45 off Paddington would make a nice fit; but it's almost 9 hours from Paddington to Rosslare this way. To get to Rosslare at 16:25 I'd need to get out of Connolly on the 13:33 train; which means I could probably get an 11:00 or so flight from London and still make it there. I'd probably get an extra hour in bed and wouldn't have to sit on an IET for 4 and a bit hours nor get on a boat which is arguably more likely to be late than the plane.
