South Acton Southbound starter signal
heart-of-wessex
11 Jun 2005
Trowbridge
Hello all,
Trying to find video reference but cab rides seem to be from Richmond towards Willesden, and any other youtube video from the platform only shows the signal once the train is leaving for Richmond
For a route set from South Acton to Gunnersbury, is the starter signal south of the station approach control or is it set and clear in advance? I know there's a Level Crossing round the corner don't know how early barriers go down
Any help appreciated!
NSEWonderer
5 Dec 2020
Hello all,
The starter signal at south Acton before the Junction spends most of its time set at red for movement towards Richmond. Usually clears to a single yellow(if the barriers are down) as the train which is coming slowly in(due to the red) arrives, conducts and completes station duties.
From what I've seen it looks to be manually cleared once the barriers are down as the starter signal protects the level crossing and Junction which only sets in the Richmond direction once the prior is complete.
Belperpete
17 Aug 2018
If they are full barriers, then they will probably be controlled by the signaller. For a train that will be stopping at the station, the signaller will take the station stop into account when deciding when to lower the barriers, and hence when the signal clears. If the barriers are lowered automatically, the signalling will likewise take the station stop into account when calculating when to lower the barriers, to avoid the barriers being down an unnecessarily long time.
5 Jan 2014
When there was a level crossing at Feltham (full barrier) The barriers always come down before the train was allowed to approach the station even though the train was booked to stop.
Northampton
Some (not sure on criteria, maybe all?) level crossings within overlaps must be closed before the signal can be cleared.
heart-of-wessex
11 Jun 2005
Trowbridge
I know if the crossing is just past a station the crossing will be down beforehand even if something is stopping there IIRC for safety reasons if a train overshoots the platform. The crossing past South Acton is round the corner but the junction off to Gunnersbury is 25mph, coming from a linespeed of 45mph so unsure if it's approach control anyway
Just looked on Google maps at Bollo Lane LC, looks like a busy road, so I'd imagine it's not set too early, one assumes as mentioned the signal is set once the train is in the station, a set up like Bradford-on-Avon where a button on the platform is pressed once the train i ready but the guard does that
There used to be a Bollo Lane Level Crossing box but unsure if that's still in operation can't see it on streetview, there is CCTV at the crossing so might be remote operated nowadays
NSEWonderer
5 Dec 2020
Im pretty sure it isn't approach controlled.
Bollo lane is now a CCTV full barrier level crossing.
Steve Harris
11 Dec 2016
ECML
I've just had a look at Open Train Times maps section and according to them the signalling which protects the crossings is controlled from Acton Wells (AW). Also by looking at Google streetview you can see that CCTV camera's were installed at Bollo Lane sometime between 2008 and 2012, which would suggest control of the crossing has moved from Bollo Lane to somewhere else and as the signalling is now controlled from AW I'd say the crossing is to.
I would look at the Sectional Appendix but they're known to have out of date data, lol
RailwayRookie
28 Jul 2023
Norfolk
Not all, but one I operate within an overlap has its preceding signal approach released and within sighting distance of the crossing and its protecting signal.
godfreycomplex
23 Jun 2016
That was certainly the case at Feltham
In regards of Acton Wells many signallers will not lower the barriers for a stopping passenger train until close to that train’s booked departure time, to minimise barrier lowering times. This does vary, depending on time/season/other safety factors
Bollo Lane (and Kew East Jn) closed in 2012 and control transferred to Acton Wells Jn.
Bollo Lane was a lovely little box. But busy and the siggys were not overly popular with local road users. I got a bit of abuse there a few times!
Steve Harris
11 Dec 2016
ECML
I can't believe anyone would hurl abuse at you Bald Rick.
Belperpete
17 Aug 2018
As I recall, the requirement used to be that if the protecting signal was less than 50 yards from the crossing, the barriers had to be down before the signal in rear could be cleared to allow the train to approach. For platform starting signals, that was reduced to 25 yards. So not overlap distance.
In such cases, once the train has been timed to a stand in the platform, the crossing can be reopened to road users. However, having the crossing close for a couple of minutes and then reopen without a train passing over, would probably make the signaller unpopular with road users, particularly if done regularly.
In some cases, where crossings are outside these distances, over-run anticipation controls have been fitted. If a train approaches too fast, then the crossing will be triggered automatically (in a similar way as happens if a train is detected over running the protecting signal at danger, but in this case without waiting for the train to actually overrun).
Northampton
Ah, interesting to know the requirements (even if they've been superseded, they probably haven't changed all that much!) Obviously 50 yards would be within nearly all overlaps so it's easy to see why myself and others have made the connection.
Belperpete
17 Aug 2018
In most cases, they would just put the protecting signal 50 yards or more away from the crossing. I suspect that most cases where protecting signals are very close are platform starting signals with a crossing immediately beyond, so 25 yards would have applied.
class397tpe
22 Jan 2022
Cambridge
Certainly does seem to vary based on the time of day at this crossing - usually quite snappy during the day time, but have routinely had waits of 3-5 minutes later at night where the barriers are brought down before the Richmond-bound train even arrives in the platform.
