Should USB-C ports be fitted to trains?
I have noticed on some of my CL. 720 journeys that some the USB sockets don't seem to work or accept the USB-A charging cord. Very random as the charging cord will fit some sockets but not others. It's as if some of the USB sockets on the train are damaged in some way
I've found that quite often - I get the impression accidentally catching the plug or tugging the cable to pull it across the long axis of the socket will permanently damage the socket so the plug slops around in it. It may then work if held in position by hand, but more likely not at all.
I also managed to drop the laptop and it landed on the USB-C plug which was charging it at the time. The metal part of the plug is bent about 20 degrees but both it and the socket (and the laptop!) still work.
krus_aragon
10 Jun 2009
North Wales
The latest Apple iPhones, Apple Watches, iPads and AirPods have switched to USB-C charging, joining their MacBooks which have had this for years. None of these will work with a standard USB port (infuriatingly for me as a Mac user who takes it on every long train journey, and the plugs are quite bulky anyway)
I'm not that up-to-date on recent Apple equipment. I know these devices (and plenty of others) now have a USB-C port on them for charging, but do you mean to say that these Apple ones won't charge if used with a USB cable with a "standard" connection on the other end (USB-C to USB-A)?
If so, any visitors to my house would be absolutely stuck for charging things. We only own one device with a USB-C "output" port, and I don't think there's a C-to-C cable in the house. (There's a fair number of A-C ones.)
birchesgreen
18 Aug 2015
Solihull
They charge fine.
