tbtc
Moderator note: Split from https://www.railforums.co.uk/threads/sheffield-city-region-integrated-plan.186433/
Some clear non-starters here. Tram-train all the way to Robin Hood Airport? I'm all for the tram-train, I'd happily surrender Rotherham Central to it, but that'd be a nonsense extension. A stop at MAGNA on the Tram-Train would mean an expensive footbridge (given the expected passenger numbers).
A lot of our problems could be solved by:
Ideal world, I'd add "remodel Sheffield station to accommodate more terminating services as the current infrastructure isn't up to the job, but that's firmly in the "Crayola" territory!
The infrastructure can struggle to cope with the existing hourly service so you'd want to have a study into demand/ feasibility before committing to the cost of additional sections of double track.
Also, there are four/hour from Sheffield to Barnsley already (a mixture of non-stop from Meadowhall and stoppers), so it may be that a second Penistone service would be at the expense of the proposed London - Barnsley service. At least nobody is suggesting putting a London service over the single track Penistone line though!
My understanding is that the Fox Valley shopping centre was built with a Stocksbridge train station in mind (I'm not saying it'd be a great idea - it's a long way from residential Stocksbridge and there's no simple solution at the "Sheffield" end - but at least there's space for a station if the pigs ever did float off into the sky)
Would that mean dumping a unit on the single track line between Barnsley and Dodworth for (maybe) half an hour whilst it waited to head back to London? That'll make reliability on the Penistone branch interesting. Or is there space elsewhere around Barnsley for a (two hundred metre?) train to lay over? Bearing in mind we are talking about the future when full length bi-mode trains should be running MML services (instead of short 222s)
The population of Wortley within walking distance of a station there is possibly going to be above single figures but not great (especially given how high the A629 is compared to the railway close to the bottom of the valley. Wouldn't fancy walking home up the hill in the dark!
Ideal world Crayonista time, but Dore would be a great terminus for all of the local trains that clog up Sheffield Midland - a couple of terminating platforms there (in addition to the Hope Valley and MML lines) would make a big difference to reliability. It'll never happen, of course...
I'm annoyed at this kind of approach - I can see why it has to be done, but a lot of the time it involves wasting time/money listing daft schemes from all far flung areas so that "stakeholders" feel that they are being represented - hence the feasibility studies or lip service paid to box-ticking proposals that are only listed to give some backwater place the idea that they are being listened to.
Personally, I'd rather see a list of three or four plans that were serious contenders (but, I appreciate that you need a messy smorgasbord of proposals from Hatfield to Penistone to Dore and all points in between, so everyone gets to feel important)
- Second platform at Dore
- Electrification of lines from Moorthorpe/ Doncaster - Swinton - Sheffield (allowing local services to be run by fast accelerating EMUs)
- Do something to fix the problem of Rotherham Central (e.g. a northbound train needs to cross the southbound line on the flat, get a path over the single track Holmes Chord, then cross the southbound line on the flat a second time as it rejoins the main line by Aldwarke) << this happens at least three times an hour (two to Doncaster, one to Leeds and occasionally one to York) and is a major problem for local reliability
Not sure why they need a feasibility study into a second train an hour on the Penistone Line, it's really not rocket science? Obviously improvements will need to be made engineering wise to accommodate said extra service.
If they did re-open the Woodhead line to Penistone, they should reinstate a service to Stocksbridge too while they are at it.
Just seen there are proposed MML services to Barnsley again, that's interesting too.
Barnsley MML is easy to do just extending an existing service though capacity might be an issue and requires some work. Penistone to Deepcar may have another advantage it would reduce journey times to Sheffield by providing a more direct route. It serves Wortley as well
Yes, nice to see that they're looking at Meadowhead and the Northern General, both would benefit from being on the tram (one line perhaps!) Slightly surprised tram/tram train to Dore isn't mentioned specifically but then I guess with HS2 as well there may not really be room for it down the MML corridoor. There may be room to extend a Northern stopper through Sheffield to Dore however and turn it there (easily do-able with two platforms I'd have thought) and would free up a platform at Midland - this would increase connectivity and give Dore a second train per hour to Sheffield.
I’m not even sure they were that behind it when the City Region Mayor was just on Calendar. Basically saying ‘we needed to create a list, so have created a list’
It’s almost a list of anything they could think of, a long list from a brainstorming session, very little is likely to ever get anywhere.
