Saxmundham to Leiston
Class15
30 Dec 2021
North London or Mildmay line
Hi all,
So the railway east from Saxmundham is going to be completely rebuilt in the next few years. A new temporary line will be built, running close to Leiston Abbey, and the existing line to Sizewell will be temporarily mothballed.
Would it be possible, to, in conjunction with these works, reinstate a passenger train service between Saxmundham and Leiston? Need not be anything more than a 3-car 755.
Leiston is a relatively big place and ideally should have a rail connection.
Thanks.
Magdalia
1 Jan 2022
The Fens
Still bigger than places like Gunnislake though, which have much longer railways to access them. For Leiston it is literally a few miles.
I don't know Gunnislake, but I can look at a map. Gunnislake has specific connectivity issues because of the Tamar and Tavy rivers with the consequent absence of a road alternative, and the branch has more than one station. Neither of those apply at Leiston.
52290
23 Oct 2015
Hi all,
Thanks.
Even more ideally continuing to Aldeburgh.
Hi all,
Thanks.
Possible, yes.
Desirable on any assessmnt of costs and benefits compared to reasonable alternatives? Not remotely.
Class15
30 Dec 2021
Possible, yes.
What would the cost actually be?
I would also note that Sizewell Power Station had to fund the Leiston Abbey refurbishment, so why not also do Leiston station?
There are enough spare 755s to spare one for a shuttle.
Conservatively, about £3m a year in crew, fuel, unit mileage, unit maintenance, ancillary and on costs.
That’s before the capital costs of building a station and any additional works to Level Crossings and signalling.
Class15
30 Dec 2021
Maybe the unit could run to Ipswich and form a 2-hourly service, providing extra services between Ipswich and Saxmundham?
Would that generate £3m of revenue each year? It would need to result in over 200,000 extra journeys, which seems unlikely.
If using just one unit, that would double add extra cost for a much reduced frequency to Leiston. But in any event there wouldnt be calacity for it between Westerfield and Ipswich.
MP33
19 Jun 2011
Thorpeness the next station on from Leiston, was opened as it was intended to be a resort. Unfortunately, it opened in 1914, on the day war was declared.
Mcr Warrior
8 Jan 2009
Not quite. I have Thorpeness Halt as opening for passenger traffic on Wednesday 29th July 1914, this according to contemporary local newspaper reports, so was a few days earlier. Britain didn't declare war until the following week on Tuesday 4th August 1914.
stevieinselby
6 Jan 2013
Selby
It would be possible sure, but very unlikely that it would be worthwhile. It would also need additional trackwork and signalling north of Saxmundham so that both northbound and southbound mainline services could use the same platform, as otherwise there is nowhere to berth the branch line train while the mainline trains come through.
Leiston already has a good bus service, with up to 4 buses an hour to Saxmundham, where passengers can connect with rail services, and a journey time of about 15 minutes.
By the time people have walked to the station on the edge of town, it's unlikely that the train would reduce that time appreciably given the better penetration of the bus services.
Running a 4-mile branch line is a poor use of resources. If you're looking at passengers making onward connections at Saxmundham then you only need to run an hourly service because trains through Saxmundham are only hourly and pass near the station so a single journey would connect with both northbound and southbound trains. That means that you would have the train and crew sitting idle at Leiston for the best part of 45 minutes out of every hour.
The only way it would be viable would be if there was currently unmet demand for additional services between Saxmundham and Ipswich, but not north to Lowestoft, and the service could run through from Leiston to Ipswich, but that would require redoubling or at least passing loops on the line between Saxmundham and Woodbridg, which at the moment can only sustain an hourly service.
When you look at Gunnislake, Calstock, Bere Alston and Bere Ferrers combined, their total population is about 7k – 7.5k, so bigger than Leiston.
And if that service wasn't running now and anyone suggested reviving it, they would be laughed out of town.
The reason that that branch line was retained is because road access to several of the villages along the route is very poor, and the geography of the area and the rivers in the way would make it very expensive to improve that road access – it certainly wasn't because those small communities specifically merited a train service.
The short distance to Leiston is actually part of the problem and why it wouldn't be a good idea!
