Rocket under it's own power?
sad1e
26 Aug 2024
When was the last time Rocket ran under it's own steam, has it even ran under it's own steam in preservation or has it been kept completely original for historical reasons?
Spartacus
25 Aug 2009
I think the best estimates place it's last running some time around 1840.
Harvester
9 Nov 2020
Notts
It does not appear to have been steamed since withdrawn from service around 1840, 185 years ago!
Mcr Warrior
8 Jan 2009
Probably shows how quickly GB locomotive design had moved on in the 1830s if 'Rocket' was deemed, by the end of the decade, to be no longer suitable for hauling even the lightest of loads.
simonw
7 Dec 2009
Spartacus
25 Aug 2009
It was that quick that Rocket was two generations behind the times as early as 1933, after Stephenson's Planet and then Patentee classes, that latter of which made Rocket look hopelessly outdated.
simonw
7 Dec 2009
Yep, I think it was well out of date by 1933.
Spartacus
25 Aug 2009
Not going to be too many lines it would be any use on, even if they had an exceptionally high loading gauge
Pic of rocket in science museum
It wasn't so much the height (I'm sure cutting it down would have been done if needed), it was the weight, or rather lack of it. For the Rainhill Trials the axle loads were tightly controlled, which limited Rocket's pulling power. If you had decent loads or hills, a Rocket type loco wasn't the answer. The Patentee's tender alone was quite a bit heavier than the Rocket.
Bevan Price
22 Apr 2010
The original 1829 built one.
Yes - it is easy to forget that several replicas of Rocket have been built - some showing it in its "final" (modified) condition. One was built & steamed in/after 1980, coinciding with the 150th Anniversary of the Rainhill trials & related events.
Sadly costs and (un)available infrastructure will probably mean that any 200th Anniversary events in 2030 will be on a much smaller scale than 1980.
Mcr Warrior
8 Jan 2009
Let's not forget, Rocket was built to do one thing and one thing only: Win the Rainhill Trials
Indeed. £500 first prize for doing just that.
BTW, how much did 'Rocket' cost to be built, back in 1829?
