Pre-grouping photographs help
Midland2F
26 May 2014
Leicester/Rugby
Hello all,
I wonder if anybody might be able to help me.
I'm trying to find books and or websites dedicated to pre-grouping railway photographs, particularly the earlier the better. I've been trying to fuse my two interests in railways and early photography and I keep hitting a brick wall at my local library and book shops, most seem to be post 1948 collections and the few images I have found are generally more engineering pictures than the train itself. Eventually I would like to do a book taking the modern scene but using the same methods/equipment of the pioneer railway photographers.
Thanks!
Bevan Price
22 Apr 2010
One problem is that most of the "old" film was too slow for use with fast moving trains in all but very bright lighting conditions***. Plus, many of the "less expensive" cameras also had slow shutter speeds. My late father's Kodak bellows camera could take photos at 1/50th or 1/25th of a second only. And you only got 8 exposures per film.
So, unless you were quite well off, and could afford expensive cameras & film, there was much less photography than is now possible.
*** Even well into the 1950s, much of "consumer-affordable" colour slide film was rated at no better than 8 ISO. Black & White consumer film was probably not much better than 25 to 50 ISO.
thewiltog
14 Oct 2011
Howden
If you can get to the NRM in York, the library has a huge range of books, as well as a complete set of the Railway Magazine.
Copyright may be a problem, although the older the photograph the less likely this is.
