Planning Another All Line Rover (September)
PeterY
2 Apr 2013
I'm in process of working out a plan for another ALR. Trying to bash as many new lines as possible.
Not being local to the these area's realistically how long would it take walk between the following stations?
Helensburgh Upper to Helensburgh Central.
Bradford Forster Square and Bradford Interchange.
I'm also looking at doing some Welsh Valleys. I know you can go from one station, by bus at the top of one of the Valley stations to another. Any suggestions?
ash39
8 Feb 2012
I've done both of those walks, looking at 15 mins tops for both of them. Definitely do Helensburgh Upper to Central rather than the other way round, as it's quite a steep hill.
Can't help with the valleys query but I think if line coverage is your main aim then using buses to hop between temini as you suggest is the way to go. Good luck
Segedunum
International Transport
22 Dec 2013
Up North
I've done Rhymney to Merthyr Tydfil as a bus and IIRC it was £3.10 between them. It's the Number 3, runs at xx03 from Rhymney and xx17 from Merthyr from 0803 to 1803 and 0717 to 1717 Monday to Saturdays. Journey time meant to be about 31 minutes though mine was late and I recall sprinting through Merthyr to make a train :lol:
PeterY
2 Apr 2013
Thank you for your advice which is very helpful in planning.
BlueFox
20 May 2013
Carlisle
I walked Helensburgh Upper to Central for the first time last week. It took about 10 minutes, but as ash39 mentioned, it's quite a steep hill, so add a few minutes if you're going in the other direction.
The last time I was in Bradford there was a free city centre bus that linked the two stations. That was a few years ago though, so I'm not sure if it still runs.
