Pendolino Livery (Vote)
Which 390 livery do you prefer ?
  • Classic Red and Silver
    Votes: 100 50.8%
  • New Flowing Silk
    Votes: 9 4.6%
  • New Flowing Silk (with window bands)
    Votes: 88 44.7%
  • Total voters
    197
I was on a 156 from Manchester to Preston and the windows were brown when we got to Preston.
Bet it wasn't spotless when you started out, unless you're talking of during snow or similar. But if it was, then that demonstrates that Northern need to employ staff to clean the windows on the platforms at each end.
K.o.R
6 Dec 2017
Probably a bit hazardous in 25kV territory, but surely they could just have someone with a Karcher jet-wash the front of the train after it stops in a terminal platform?
Clip
28 Jun 2010
Its not just the overheads you have to worry about but also the hazard you would create on the platform by making it wet too - a man with a brush to do the cab windows is about the best you'll get really.
pt_mad
26 Sep 2011
WARNING: PAINT WIBBLE
I have always thought the original virgin livery dull and boring. The colour palette seems overly subdued and the silvery gray a magnet for dirt.
Indeed. And a lot of silver on a train livery was very 'naughties'. A symbol of the second generation privatisation liveries with white probably making a bigger appearance currently.
Rail.Fan
4 Nov 2015
Kent
I feel a lot of Naughties designs are more futuristic than Modern Liveries, I feel in the 2020s we will see White continue to die as in general we are seeing Grey/Silver take over White is the main shade in design.
Rail Blues
2 Aug 2016
Isn't the point of the re paint to get the 390s ready for return to the Roscoe at the end of the wcml contract? Remove the flowing silk vinyls and you've got an unadorned white train.
Doomotron
25 Jun 2018
Kent
To be honest, if it was completely on white with no livery, there'd be a lot less complaints about a half-finished livery!
Domh245
6 Apr 2013
nowhere
Not quite. The repaint was required as a maintenance procedure, and given that Virgin are only guaranteed to run the west coast franchise for a short while longer, it made little sense for the ROSCO to pay to paint it in a Virgin specific livery if it'll need rebranding a few years down the line. You are right about the removing the vinyls to just give a plain white train for the next TOC to adorn as necessary (in virgins case, by adding more red vinyls along the train). There isn't any need to return trains to the ROSCO/next operator in a completely plain livery, the extent that most franchises go to is to simply remove their own (main) branding and leave the rest untouched.
Rail Blues
2 Aug 2016
Thanks for clearing that up!
Harbornite
7 May 2016
Nah it was good. The only bad thing about it was the stripey doors, they weren't necessary for the purposes of contrast because doors with a solid contrasting colour would have sufficed as they do for everything else.
