NRN Cab Radio
10 Dec 2008
Afternoon gents,
I am looking for any information regarding the cab radio numbers fitted to most rail units.Is it possible to obtain a list of these before GSM-R takes over ?
Any information would be most gratefully received.
Alan
Turbostar
15 Aug 2006
Plymouth, Devon
Eh? You want to make a private phone call to someone??? lol :lol: Isn't there a ban on taking private phone calls whilst driving??? lol :lol:
GB
16 Nov 2008
Somewhere
I seriuosly doubt that kind of information would be made available to the public.
Turbostar
15 Aug 2006
Plymouth, Devon
I would have thought as well, calls are monitored, and if your caught taking a private call on the NRN (whether you can actually do it or not I don't know), I would have thought it's instant dismissal (once, if your driving, you get to your destination.)
10 Dec 2008
Hello,
Thanks for the replies.Firstly i dont work on the railways,i am an electronics engineer,but have an interest in rail comms,as an enthusiast.The system is one way unless initiated by control,and calls have a 3min limit from mobile to base controller.I fully appreciate the safety aspect applied to its usage.The system is to be downgraded in the near future for a modern digital network and i wanted to update as many of my records before its demise,as possible.
Rgds,
alan
GB
16 Nov 2008
Somewhere
Hello,
Rgds,
alan
Will be sometime before GSM-R gets a complete national rollout so I suspect there is some years left in NRN land.
10 Dec 2008
Yes,the initial closedown was earmarked for 2012 but i have heard that it may be extended up to 2015.2012 is the date Ofcomm were bandying about but i suspect that where new GSM-R equipmemt is fitted it will be used straight away if the infrastructure is in place.I was told that new masts were in place in Sheffield station,but i cant confirm this myself at present.
Alan
Turbostar
15 Aug 2006
Plymouth, Devon
Read post #5, as already stated, this info is not available to the public. And, you can also get in serious trouble I would of thought trying to access the network. You've been warned.
10 Dec 2008
Thanks for the reply Mart.I have no intention of accessing any network and also this is not accessible as its a closed network.I asked for info for the historical record not for any technological communications access.This is just not possible unless you are already on the net.I am aware that the info is not in the public domain re the idents but all the other info is in the public domain and is freely available on the net and in books.Everything about the NRN network is public domain.Just do a Google check.
Theres no harm in asking....
Aalan
Oh and one thing i should have mentioned.The info is available in the public domain via the Freedom of Information act via the Rail safety Board site.The entire database of rolling stock can be accessed by appointment.
regards,
Alan
driver9000
13 Jan 2008
NRNs are changed regularly between trains anyway so any list you make will need updating with each changeover.
NRN is due to be switched off in 2012, the frequencies are allocated to Olympics security radios.
10 Dec 2008
Yes that is correct hence the reason i wanted to get the list together before it went.The new GSM-R system will fill in hopefully all the gaps which were inherent in the NRN system.As for the Olympics Trunked network going onto that segment of band,this will be a temporary measure as i understand the band is earmarked for additional DAB systems and also to allow for a power increase by current DAB users further up the band.
Alan
driver9000
13 Jan 2008
when GSM-R is installed nationwide on the rail network NRN will be switched off and the cab radios removed. The GSM-R system has been on trial in the Strathclyde region for a couple of years using class 320 EMUs. I know Northern have begun fitting GSM-R equipment with 153307 definitely having been wired up a circuit breaker added and a small panel added to the right of the desk added, although after testing the head unit has been removed until lineside infrastucture is installed.
10 Dec 2008
Yes thanks for that.I had heard that they were fitting panels and head units for testing.I think that the number of heads available and the number of masts they install will determine how long it will be before they switch it on.I dont know whether they have loads of engineers on this but they will still need plenty to keep NRN going till they are ready.Thanks for your comments.
Alan
TDK
19 Apr 2008
Crewe
Alan
I am not sure but I think the NRN runs on a channel system where the NRN will automatically lock into a channel in the frequency range of 190mhz - 220mhs NFM. I do not think an NRN radio has an actual number but has a code for each radio, the radio when on displays a code number for that actual radio.I do not think the signaller can actually contact an individual NRN radio and can only alert the driver with an emergency call that all sets in the area can receive.
The CSR is a different system all together and the IVRS is again a different system where the signaller can contact a unit individually.
10 Dec 2008
Thank you for your comments TDK.You are correct as to how the system operates.
The main control center can use the system to contact a mobile whereas the signaller must put out an area broadcast.
Alan
driver9000
13 Jan 2008
The signalman doesnt initiate emergency broadcasts, that is done by Network Rail control.
10 Dec 2008
Correct,i should have added this at the end of my last reply.All calls must go via the control center.The signaller must inform control before the train can be contacted.
A.
vitesse
10 Sep 2008
AFAIK Any individual radio cannot be called directly, hence you would get a call along the lines of "Driver of two delta three four please contact blah". However you can ring out to internal and external numbers directly as my DI demonstrated by ringing his mobile (on depot of course - and not answered)
driver9000
13 Jan 2008
An NRN can be called directly - I have received such a call. When it 'rings' it makes a very annoying warbling noise. This feature is rarely used, and was only used for me when my set failed and I didnt have a mobile phone with me, if they dont know the number of the radio they will put a general call out. The public phone system is not accesible from the NRN, mobiles can be configured to work on the BRT network.
djw1981
10 Jul 2007
You may find that there are some more communications types from NR etc over at www.railchat.co.uk not to degrade the info given here, but they have several comms and telecoms types there who may be able to help you with the details.
vitesse
10 Sep 2008
It certainly is, as i have seen this done. I'm probably wrong on on the other bit then :)
10 Dec 2008
One query that i have had for a while.When heritage steam loco's work over NR lines,what kind of radio is fitted ? Are they just handhelds or is a more robust unit used ?
Alan
driver9000
13 Jan 2008
As far as I know Steam locomotives carry the portable radio set, it works in an identical way to the fixed radio sets.
10 Dec 2008
Thanks for the reply.I wonder what they will get when gsm-r takes over.Probably a small mobile phone.
Alan
