Network West Midlands nBus and nNetwork Validity Map Oddity
trainJam
26 May 2023
West Midlands
The image is from the Birmingham local area integrated transport map (https://www.tfwm.org.uk/plan-your-journey/discover-the-west-midlands/local-area-maps/), accessed 12th November 2023.
For comparison, in square A10, bus route 202 goes completely outside of the valid area.
If you look closely at square D10, bus route 49 seems to leave the light cream area (nBus and nNetwork validity zone) for a very small section of the route. It is not the easiest thing to spot, but I can see the grey dashed line above the dark blue road, implying that the road does cross into the dark side.
Theoretically, does this mean that nBus and nNetwork tickets are not valid here? :|
dvboy
6 Sep 2011
If you take a look on Open Street Map you'll see that Harbinger Road does indeed cross into the dark side. https://www.openstreetmap.org/#map=18/52.40660/-1.91474
I'd be amazed if any of the drivers even realise they're crossing the county boundary and back. The two bus stops that are in Worcestershire have TfWM flags. Two of the street signs are Birmingham design and at least two of the street lamps have the yellow ring which is a Birmingham thing.
