n-Network Pass
JJUK
10 Dec 2006
West Midlands
Hi Guys and Girls,
I have an n-Network pass which I use to get to work, It allows me to use the Buses, Trains and The Midland Metro.
I thought you could only use this pass on London Midland Trains, but then I found out you could use them on Arriva trains as well. But do Virgin Trains and XCountry accept them as well?
Thanks in Advance
JJ
Old Timer
24 Aug 2009
Hi Guys and Girls,
Thanks in Advance
JJ
They are valid on all trains running within the area irrespective of operator.
Mojo
7 Aug 2005
Yes ^^ See CLICK to go to NRE somehow (as said on linked page) it is valid on Northern Trns but I cant see where!
That link is for the West Midlands Day Ranger (WMDR) which is different to an nNetwork. As Old Timer states, the nNetwork is valid on all TOCs in the area: London Midland, Virgin Trains, Arriva Wales and CrossCountry (not WSMR as there are no journeys for which they could be used as Wolverhampton is pick up/set down only).
Northern run trains between Stoke on Trent and Kidsgrove in the WMDR area.
mumrar
26 Sep 2008
Redditch
Could you not use WSMR for Wolverhampton to Tame Bridge or reverse as it's wholly within in the Network area?
Mojo
7 Aug 2005
WSMR trains set down at Wolverhampton on their way south and are pick up only on their way north so it would not be possible to use them for Wolverhampton - Tame Bridge.
JJUK
10 Dec 2006
West Midlands
Thank you very much for that, I was not sure If Cross Country and Virgin Trains would except the ticket.
Its £83 something but I think it is worth it.
Once again thanks.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Sorry to bring this back up.
Just had a look - where is Stoke - on - Trent and Kidsgrove on the nWM map?
I even had a look on the find a stn button but still no luck!
Read Mojo's post again ;)
http://www.nationalrail.co.uk/manag...d8690e40c16f/areaMap/West_Midlands_Ranger.pdf
