MK3 vs MK4 vs MK5
Legolash2o
27 Sep 2018
Hey,
I was wondering if someone could tell me the differences/benefits of having MK4 stock over MK3 and MK5 over MK4.
Thanks.
In my view the only benefit of Mk4 stock is power doors. It is otherwise cheap rubbish built down to a price with the worst ride on the network other than a Pacer.
Mk5s are of course new and so have all the benefits of new stock e.g. properly working aircon.
E_Reeves
25 Oct 2015
West Midlands
I imagine a benefit of Mk4 over Mk3 is the power doors which means a faster dispatch time, less station staff needed and added safety and comfort for passengers
sprinterguy
4 Mar 2010
Macclesfield
Mark 3
Built 1972 - 1988. 23 metre length. Fully integral steel monocoque construction. BREL BT10 bogies. 125mph maximum speed.
Slam doors and track discharge toilets (Some vehicles now being refurbished with sliding plug doors and retention toilets). Seated 72 in standard class when new, now seat between 64 and 84 in differing layouts.
Built by BREL for use in both fixed formation HST trainsets and as conventional loco-hauled coaching stock.
First prototype vehicles built in 1972, first production vehicles entered squadron service in Western Region HST sets in 1976.
HST vehicles are designated mark 3, and utilise a non-standard 415V three phase train supply.
Locomotive-hauled coaches were classified Mark 3A, and were initially deployed on the West Coast main line, as well as with Scotrail from 1979 on Edinburgh - Glasgow push-pull services.
A new batch of Open First and Open Brake First vehicles, classified Mark 3B were built in 1985 with Advanced Passenger Train-style 'IC80' seating and revised lighting for 'Manchester Pullman' services, replacing the mark 2 vehicles which had been in service since 1966. The three brake vehicles, 17173 - 175, built for these services were the only mark 3 passenger brake vehicles constructed, and are now in use with GWR on their 'Night Riviera' sleeper services. The last mark 3 vehicles contructed were 52 Mark 3B Driving Van Trailers for West Coast main line services in 1988, to allow these services to operate in push-pull mode.
The design was adapted for Irish Rail and for the Class 442 'Wessex Electrics', which both featured powered swing plug doors.
Mark 4
Built 1989 - 1992. 23 metre length. Fully integral steel monocoque construction - heavier than mark 3s. SIG BT41 bogies. 140mph maximum speed, but restricted to 125mph due to the signalling system on the ECML being unsuitable for 140mph running.
Powered swing plug doors and retention toilets. Seat 76 in standard class (68 in 123xx vehicles with disabled facilities).
Built by Metro-Cammell between 1989 and 1992 for use on the East Coast main line after electrification in combination with class 91 locomotives.
Standard 1000V train supply allows them to be powered by any appropriate train supply fitted diesel or electric locomotive.
Time Division Multiplex multiple working equipment allows push-pull operation between Mark 4 DVTs and class 89, 90 or 91 electric locomotives.
Bodyshells built to accommodate a tilting profile of 6 degrees (IIRC) to permit a future order of Mark 4-T tilting vehicles for use on the West Coast main line, for which SIG would have developed a new design of tilting bogie that probably would have been akin to that now found beneath the Class 390 Pendolinos. Order not taken up.
Mark 5
Built 2017 onwards. 22 metre length (22.37m driving/end vehicles, 22.2m intermediate vehicles). Fully integral aluminium monocoque construction. CAF low trackforce bogies. 125mph maximum speed, but restricted to 100mph due to the capabilites of the locomotives they will work with.
Powered sliding plug doors and retention toilets. Seat up to 69 in standard class (Transpennine Trailer Standard vehicles).
75 Mark 5 vehicles being built for Caledonian Sleeper. Seated brake, lounge and sleeper vehicles. 8 x 8-car rakes (64 vehicles) in use each night.
66 Mark 5A vehicles being built for Transpennine Express for use on Liverpool/Manchester Airport - Scarborough/Middlesbrough services. 13 x 5-car rakes with seated driving trailers (Driving Trailer Standard) to be used in push-pull mode with Class 68 diesel locomotives, plus one spare Driving Trailer. 12 daily diagrams, with 1 spare set.
Sleeperwaking
20 Oct 2018
I think it's also easier to upgrade the Mark 4s to comply with the latest standards than the Mark 3s, mainly wrt the Persons with Reduced Mobility TSI door requirements, as opening a Mark 3 slam door isn't the easiest for a fully able person let alone someone who's disabled. The PRM TSI would also require fitment of accessible toilets. There's a date when all UK rolling stock has to comply with the PRM TSI, a quick Google suggests 1st Jan 2020 but I haven't checked in detail. CrossCountry have recently unveiled a HST / Mark 3 set with powered doors, so it is possible, but it's not the simplest thing to do.
Darandio
24 Feb 2007
As well as GWR and ScotRail. Plenty of discussion on here about Wabtec and the trouble in doing the conversions!
superkev
1 Mar 2015
west yorkshire
I always thought it strange when I'll those Irish Mk3s with power doors wheweren't snapped up as a Mk3 with power doors prob best of lot.
K
507 001
3 Dec 2008
Huyton
K
This has been discussed at length. They would have required quite a bit of work (mostly to do with ETH wiring IIRC) to make them suitable.
sprinterguy
4 Mar 2010
Macclesfield
You're quite correct that the deadline date is 1st January 2020. Each of Crosscountry, Scotrail and GWR received one refurbished set apiece around August: That just leaves another 4 sets (32 vehicles*) for Crosscountry, 10 sets (44 vehicles*) for GWR and, ahem, 25 sets (117 vehicles) for Scotrail. In less time than it took Wabtec to deliver the first 16 completed vehicles....
...But that's been well documented in other threads. There does seem to have been progress in releasing additional vehicles/sets for GWR and Scotrail, and Crosscountry's second set has gone in for conversion now.
*Includes spares
Darandio
24 Feb 2007
They would also be 5ft 3in gauge as well wouldn't they? Although i'll admit i've no idea how much work that entails to put right.
61653 HTAFC
18 Dec 2012
Bogie swaps would be fairly simple. Plenty of things went the other way, including a former Gatwick Express set (though I don't believe this saw much use).
